Old 04-30-2019, 03:45 PM
Bob Y Bob Y is offline
Default Peanut Butter Adhesive Release
Took the dreaded step today of removing the canopy after completing the fiberglass lay up. Wasnít sure what to expect but was pleasantly surprised by the canopy itself, BUT... I was shocked at the amount of adhesive residue left on the fuselage after removing the duct tape. Not sure if it was old tape, the amount of time since applying, cheap brand, or what, but I had a real mess on my hands. Started using Goo Gone adhesive remover but the going was very slow. I jokingly asked my wife if she wanted to help. She got a jar of smooth peanut butter and smeared it on a bad area for several minutes and... IT REMOVED THE ADHESIVE. It even loosened some epoxy that had dripped on the fuselage side sheets! Just thought Iíd pass this trick along.
In hind sight, it might have been better to have applied a layer of Mylar packaging tape first to protect the skins. Hopefully I wonít need to do this again but might be a consideration for those of you that havenít started your fiberglass work.
Moral of the story - donít be afraid to ask for help. Never know who can help.
Old 04-30-2019, 03:46 PM
bkervaski's Avatar
Nice! You could probably get your dog to do most of the work removing it
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-30-2019, 04:20 PM
csdominey csdominey is offline
Have used it for removing old masking tape adhesive. Interesting chemistry of peanut butter!
Old 04-30-2019, 09:12 PM
Wow! Hadnít ever heard that. Iíve been using acetone if Iím cleaning bare aluminum
Old 05-01-2019, 03:27 AM
mike newall's Avatar
It's amazing what girls know.....
I'll get my coat
Donated in 2019
Old 05-01-2019, 05:24 AM
Sam Buchanan's Avatar
been here awhile
Makes the plane smell good!
Sam Buchanan
RV-6
Fokker D.VII replica
Old 05-01-2019, 06:45 AM
olyolson's Avatar
olyolson olyolson is offline
Default Peanut butter
With all the hours your wife saved, you should take her out for a nice dinner. Sheís a keeper!
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 05-01-2019, 09:46 AM
E. D. Eliot E. D. Eliot is offline
Default Options
I layed down six layers of 6 mil plastic on top of the fuselage instead of tape. It was too many layers and the gap between the fuselage top and the bottom of the layup was too large. Just had to do some sanding on the bottom of the canopy where it meets the top of the fuselage. No tape, etc., required. Worked well and no worry about lifting off the completed fiberglass work. I'll do the same next time only use only two layers of plastic sheet.- easy.
Building finally
Old 05-02-2019, 07:38 AM
Snowflake's Avatar
FYI - WD40 works well too on most adhesives i've tried.
Rob Prior
Old 05-02-2019, 07:49 AM
wjb's Avatar
wjb wjb is offline
Also, orange oil (sold as a bike parts cleaner at my local shop) works great on adhesives that acetone, alcohol won't touch. Also smells very good!
Bill Bencze
N430WB RV-7 #74152, tip-up; IO-360; CS. Pushing toward first flight in 2020!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2020 donation happily made
