Old 04-24-2019, 12:53 AM
rgmwa rgmwa is offline
Default RV-12 clock install
I've got a 12V electric clock that I'm thinking of installing in the RV-12's panel to replace a very nice but now deceased vintage 8-day mechanical clock. I'm sure it would be trivial task for many of you, but what's the best way to do it? The clock has a light, but I don't need that. Just need to know where the red and black wires should go without shorting out everything in that maze of pre-fabricated wiring that makes the RV-12 avionics installation so easy.
rgmwa
RV-12LR 912ULS
120346
Old 04-24-2019, 05:52 AM
If your RV-12 has the original 5 amp power outlet inline fuse connected to the battery, then tap into that circuit with the clock's red wire. If not, install a new inline fuse holder to the battery positive terminal and use a 3 amp or smaller fuse. Of course the clock black wire connects to ground (earth).
The clock could eventually run the battery down if isn't recharged periodically.
Joe Gores
RV-12 Flying
Old 04-24-2019, 06:51 AM
John-G John-G is offline
If you don't want to run a wire all the way to the battery, consider this option. Pin 14 on the connector coming out of the back of the AV-50001 Switch & Fuse Module is a spare ... it has +12 volts on it but no internal fuse. That is connector ES-205208-1 on the wiring diagram. Note: Pin 14 is not always "hot" it is only hot when the master switch is on, so it would be necessary to reset the clock for each flight .... (but you won't drain the battery between flights).
All you need to do is crimp a pin on a wire and insert it into position 14 on the connector and you will pick up the +12 volts needed for your clock ... run that wire to an inline fuse for protection. I can't imagine the clock needing more than a 1 or 2 amp inline fuse.
I wanted power for a switchable left landing light and tapping into pin 14 on the Switch & Fuse Module worked out great.
Happy flying,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2020
Old 04-24-2019, 09:17 AM
I just wear a watch. It doesn't run the plane battery down. It' doesn't get subjected to all the vibrations. It doesn't need to be wired up. Simplicity.
Old 04-24-2019, 10:04 AM
eBay has many working 8-day clocks. And a good watch repair shop can often fix them.
I'm putting one on my RV-3B.
Old 04-24-2019, 11:15 AM
All helpful replies
Joe: my RV-12 is the early Skyview version with the conversion harness, so it's possible. I will check. I planned to put a small switch under the panel to isolate the clock and prevent the battery drain.
John-G: I saw that unused pin on the wiring diagram and had the same idea. Thanks!
NinerBikes: can't argue with that of course, but that vintage clock looked great in the panel and was surprisingly useful. Now there's a hole there, and just blanking it off seems such a waste of a well engineered hole.
Dave: Yes there are, and that's the other option I'm still considering. The problem is they are old. Mine was refurbished, but the mainspring eventually broke from fatigue and replacement parts are hard to come by.
Thanks all. I think that pretty well covers all the options.
rgmwa
RV-12LR 912ULS
120346
Old 04-24-2019, 12:51 PM
mike newall's Avatar
You may have clearance issues with the pendulum under the dashboard though.....
Donated in 2019
Old 04-24-2019, 04:55 PM
bobnoffs bobnoffs is offline
i found an 8 day vintage clock with a timer function. way cool. hole is cut in panel waiting for it for my 12.just because there was one in my piper that i learned to fly in.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 04-24-2019, 06:10 PM
rcarsey rcarsey is offline
i'm showing my age.. i just had to google "what is an 8 day clock?".
Old 04-24-2019, 06:44 PM
... and I'm showing mine by knowing what it is and how to use it.
rgmwa
RV-12LR 912ULS
120346
