Old 03-14-2019, 10:04 AM
mantry mantry is offline
Default FS: 2004 Vans RV7 Slider 180hp CS
They say we never really OWN an airplane. We simply take care of it until it is time to pass it on to the new owner. Well that time has come for N6113. I'm wanting to get back to a true 4 place aircraft that won't mind landing on a remote island in the Great Salt Lake, or near a old one time truck stop along I-80 for hot dogs and snacks and maybe taking the wife camping to a remote camping spot in Idaho's backcountry.
She was ordered on 6/11/01 and put together by an active VAF'er here on this board and she was born (had her certificate issued) on 10/8/04. I got her in December of 2014 from the second owner and I had her stewardship for 113 hours over these past 4 plus years and enjoyed every hour we spent together.
I think it is a fine, fine example of the VANS RV-7 line and I think she looks as the good as the day she was born. I think you will agree with me that the build quality and craftsmanship are excellent and the paint and finish are as well (but certainly I'm biased) I'd like to think I improved her over the time and added some additional features and nice touches.
Now it's time to pass her on to the next owner to take care of her.
Enjoy!
RV Model: RV-7
Quick Build (QB) or Standard Build (SB): Standard Build
Slider or Tip Up: Slider
S/N: 70202
Asking Price: $94,000.00
IFR/VFR: VFR
Link to additional pictures:
Overview https://photos.app.goo.gl/9KWRUttRSBeAeZEF7
Exterior https://photos.app.goo.gl/QcXb1twkA3YgHSHRA
Interior & Panel https://photos.app.goo.gl/B33TFo5roQCd4b8r8
Engine https://photos.app.goo.gl/jHFBA2u9X6vDMnsg6
Misc https://photos.app.goo.gl/6UqeSmPazh7wVz1c9
- above link includes pictures of: __X_ External __X_Panel __X_Upholstery __X_Engine
Why selling: Going back to 4 Place aircraft more suited for off airport operations
Total Time (hrs) on airframe: 775.7
First flight date: 10/8/04
Original Builder (y/n)?: N
- If not, seller is currently owner #___3__.
Empty Weight (lbs):1128.0 (1800 Gross)
- CG (empty weight - inches from datum):79.92
- date of last weighing: 3/13/19
Year painted: 3/31/05
- Painted by: Unsure, Owner?
Engine Make/Model: Aerosport Power O-360-A1A
- HP: 180
- Total Time Since New (hrs): 775.7
- Time Since Overhauled (hrs): 775.7
- Ignition: Slick Conventional Mags (Was originally set up for Electronic Ignition, but those mags were removed by owner #2)
- Carb/FI: Carb
- Exhaust system: Vetterman
- Engine Purchased from: Aerosport Power
- Engine Assembled by: Aerosport Power
- Date of last compression check: 3/5/19
- - Cylinder #1:79
- - Cylinder #2:79
- - Cylinder #3:79
- - Cylinder #4:77
Other unique features FWF: Aircraft was originally set up for electronic ignition but previous owner removed the mags and replaced with conventional mags and removed control boxes under panel but the wiring and pickup sensors are still in place. B&C SD-8 Standby alternator with Essential bus. Engine pan heater, Odyssey PC680 battery.
Prop:
- Make (FP or C/S): Hartzell Blended AIrfoil CS
- Model: HC-C2YR-1BF
- Pitch: Constant Speed
Flaps (manual / electric): electric
Rudder Trim (manual / electric): manual
Elevator Trim (manual / electric): manual
Aileron Trim (manual / electric): manual
Strobes Make/Model: Whelen A650/NDA
Landing Lights Make/Model: Duckworks
Age of tires/tubes: Dec 2013 (Goodyear Flight special II)
Avionics: Dynon D10A, Apollo S30, Garmin GPSmap 496, Garmin GTX320A, uAvionix EchoUAT/SkyFX ADSB-OUT/IN (Jan 2020 Compliant), PS Engineering PCD-7100 Intercom/CD/MP3), Navaid AP-1 Autopilot with GPS/COMM Coupler, EI UBG-16 Eng Monitor with OAT, Oil Temp, Volts/Amps and annunciator light, EI FP5-L Fuel Totalizer, GPS/VOR/LOC indicator, Flight Data Systems T-30 Electronic Tach, 2 Commit Lift 2 port 2.1 Amp USB outlets, ACK E-01 ELT, AmeriKing AK-350 Encoder.
Interior: Fabric Seats and lightweight side panel covers, Flightline Interiors carpets
Modifications: Tip up Sliding Canopy for baggage compartment access, Doug Bell Tail fork, Flyboy lightweight tire, Rocket Tail link
Real World Cruise Figures:
- __172__mph IAS at __23____" of MAP spinning __2300__rpm while burning _10.3_ gph.
- __183__mph IAS at __24____" of MAP spinning __2400__rpm while burning _12.8_ gph.
Past incidents/repairs/damage repair: Repaired 2 improper Cherrymax rivets in Aileron attach bracket. Repaired leaking Right Fuel tank access panel and fuel sending unit, Replaced Right Fuel tank sending unit. Replaced Alternator, Replaced Starter, NO DAMAGE HISTORY
Service bulletins/Change notices that have been complied with:
SB 14-01-31 No cracks found
SB 16-03-28 No cracks found
SB 14-02-05 No cracks found
SB 12-08-14 Correct bolts installed
SB 11-9-13 Slosh not used on tanks
SB 07-4-12 Flap rod end bearing is secured
SB 07-02-6 Pax stick permanent attached (NO)
SB 06-9-20 Secured by not new style(WD-415-1)
SB 06-2-23 R tank complete, L tank not done
Date last annual: 3/5/19
- Maintained by: Owner, signed off by AP/IA
Date last transponder check: 2/26/19
Date aircraft last flown: 3/12/19
Willing to deliver: Y___ N___ (depends on distance)
Other items not listed above: Oil analysis is good, done both from original builder and myself. 2016, 2017, 2018, 2019 (Sent off but results not back yet). All show good healthy engine.
Borescope of cylinders and valves done in 2018 and 2019, all show good healthy engine (Pictures available on request)
ADSB-OUT 2020 Compliant (ADSB-IN/OUT via uAvionix EchoUAT/SkyFX)
LEMO and Conventional headset jacks.
iPad mount (iPad not included)
ALWAYS HANGERED
Extra's include:
*Flightline interiors lightweight canopy cover (never used)
*Tailwheel towbar
*Extra fuel Cap (and extra o-rings)
*Extra Fuel Quick drains (and extra o-rings)
*Tire pressure service (cap removal, schrader valve extension, and Pressure gage)
*Antisplat Aero Collapsable gust lock (An amazing product and amazing quality)
*pitot cover
*Lots and Lots(100's) of extra screws, bolts and hardware to have on hand should you need an extra
*Travel chocks and carrying bag
*Odyssey Approved Battery maintainer
Contact Info
- name: Mark Antry
- voice/text: 801-872- thirty four ten
- email: markab320 (at) gmail.com
- Preferred hours to call: 0800-2000 (Mountain)
Donation for 2019 complete! Thanks VAF and DR! (Worth every penny!)
Old 03-14-2019, 06:56 PM
dreed dreed is offline
She's a beaut! Good luck with your sale!!!
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
IO-390 hanging now
Hartzell Composite prop taking up valuable shop space
2018 and 2019 VAF dues paid
Old 03-14-2019, 07:49 PM
**** SALE PENDING ****
(Boy I should have had a hanger full of these planes...)
