Old 03-10-2019, 05:39 AM
toddramsey's Avatar
toddramsey toddramsey is offline
Default WTB: wingtip, tail, and ldg lights
I appreciate VAF and the good advice and good buys I have found. Time to close my wings and make lighting purchases. Everything I find new seems to be 1k +. Im trying to build on a budget and struggle with a grand alone for lighting. Ideas out there? Or is this one of those just get the checkbook out moments?
Todd Ramsey
Greenville, SC
Reformed scratch builder
RV-9A in progress
Old 03-10-2019, 06:06 AM
AviatorJ AviatorJ is offline
I flew a 10 with the Vans lights which seemed to work fine.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 03-10-2019, 06:26 AM
jjbardell jjbardell is offline
I have a lighting system on my plane that is coming off in a few weeks. No idea of the mfg or model. It appears to be a standard Vans tail light. A belly strobe, halogen wingtip lighting, DIY LEDs for positions and another DIY wingtip strobes.
All works great. Strobe box appears automotive.
As part of my panel swap Im going to all FlyLED lights.
I can take pics if your interested as Id sell it really low just to get rid of it all.
Thanks. Josh.
Cheers, Josh
N67LJ RV9-A TU
O320 160hp / Catto 3
rvpilotlife.wordpress.com
19 supported!
Old 03-10-2019, 07:25 AM
sibriggs sibriggs is offline
Default MicroBurst III
Consider one of these, as then you don't have to run wires to the tail.
MicroBurst III Forward facing Wingtip Nav, with CometFlash 180 degree LED-Strobe and rear facing White Nav MB3G 01-0771507-01
Steve Briggs. RV9, G3x, G5, VPX, GTN625, PMags, A&P, IA, ATP-CFII
Old 03-10-2019, 02:16 PM
GeoffP GeoffP is offline
Default lighting for my RV-9
Todd,
For my RV-9 build, I got a FLYleds works kit. This does involve assembly (which is the fun part anyway), but is more in the budget range you're looking at.
I had the same thoughts of overall expense for lighting and I was certainly keen to trade effort for a $$ saving.
RV-9, Empennage mostly done.
Old 03-10-2019, 02:48 PM
TShort TShort is offline
I second the FlyLEDs setup.
Very happy with my LEDs from them.
Thomas Short
KUMP - Indianapolis, IN
RV-10 N316JS bought / flying
RV-8 wings / fuse in progress ... still
N329TS (had it, lost it, looking for new number)
Old 03-10-2019, 03:53 PM
toddramsey's Avatar
Default Thanks
Sounds like I need to take a closer look at the Fly leds.
Todd Ramsey
Greenville, SC
RV-9A in progress
Old 03-10-2019, 07:16 PM
alcladrv alcladrv is offline
I have a Whelen position and strobe light system that I removed from my RV that could save you some money. Please check your PMs.
Old 03-10-2019, 08:29 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Hi Todd
I'm pretty sure you'll find our products are within your budget.
And in keeping with the whole DIY aspect of building you can easily build your build your own (bright!) lights as well!
Happy to answer your questions here or via email: paul at flyleds dot com
Thanks to all for the recommendations!
Paul McVitty
Flyleds.com
VAF advertiser
Old 03-10-2019, 11:45 PM
Robin8er Robin8er is offline
https://www.kestrobes.com/double-dual-magnum/
http://www.duckworksav.com/WTLightKits.html
This is what I used on my plane. Kuntzleman has strobe/LED Nav in one unit, then I put one Duckworks LED light in each wing tip. Should be about half the price of what you have been looking at.
RV-8
N695RA Reserved
Emp and Wings done, working on Fuselage.
Born to fly, forced to work
