Old 10-23-2018, 08:38 PM
Jimbo54 Jimbo54 is offline
Default Gas, Cans, & Bonding
Newer member here. If this is already clearly covered in another thread, I apologize. I've been reading so many conflicting and unclear posts, blogs, and articles my head is spinning.
1. Originally, I thought in a Rotax 912 ULS I was going to have to run "Clear" - non-ethanol, high octane gas. After reading many things, including info right from Rotax, I now believe I can safely use AKI 91 w/ 10% ethanol. Is this correct?
2. Again, from reading many conflicting articles/postings, I am confused about the proper container to use in humping fuel to the airport: plastic vs. metal. I've read that the action of pouring gas through plastic creates static buildup that can jump to the fuel/air mixture when entering the plane. I've read that metal is safest and yet most pictures/videos/and even ads have plastic jugs being used.
3. Bonding: I cannot find any picture or video of someone demonstrating bonding their portable gas can to the plane. My CFI doesn't bother; he just pours directly from the plastic 5 gallon container into the plane.
4. Do most RV-12 owners recommend using Mr. Funnel, and if so, which model.
Thanks in advance! Jim
Old 10-23-2018, 08:53 PM
Jim,
Iíve heard accounts of static buildup on plastic cans too, but Iíve never encountered it in 6 1/2 years of fueling from ungrounded plastic cans. I do put a finger on some bare metal part of the airframe while holding the can before I pour in any fuel, but Iíve never felt any discharge. Out here in the dry Arizona desert I think I would have seen something if it was an issue. Maybe someday Iíll find out different the hard way, but in well over 500 fueling evolutions with the plastic cans (most involving at least two cans) Iíve had no static problems.
My can nozzles have a coarse filter in them. So far no gascolator debris at 6 annuals.
Iíd gladly use a grounded gas pump if my FBO offered autogas, but in absence of that Iíll continue as I have been.
Rich
Old 10-23-2018, 09:15 PM
sf3543 sf3543 is offline
In response to:
1. 10% ethanol is fine and ultimately preferable to 100LL, although it too can be used albeit with some shortened maintenance intervals. I think I remember reading that Rotax says 15% ethanol is ok, but Iíd have to look that one up to be sure.
2. Iím sure either is fine since they are both approved for fuel. I uae plastic 5 gal cans myself.
3. I donít use any bonding when I pour the gas into the plane; however, I do make sure to take the jugs out of the truck and set them on the ground to fuel them up. Some newer trucks have a warning label inside the bed telling you to do that.
4. My jugs have a coarse screen inside the funnel. I donít use any other filtering than that and havenít had any issues
Just my experiences.....
Good luck
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV6 (sold)
RV8 (2)(sold)
RV12 (sold)
RV3B (flying)
Legend Cub
Old 10-23-2018, 09:26 PM
Same here... pour from Briggs & Stratton 5 gallon plastic directly into tank neck with no funnel. Poring spout on can has a course screen. 400TT using 93E10 and nothing ever found in gascolator bowl during disassembly for inspection. I have found debris when draining sump before daily flight - but very rare instance. The design of the gascolator bowl is self cleaning when sumped. The fine screen in the gascolator has never allowed any debris into the carburetor float bowls.
Hinckley, Ohio (1OA2)
EAA #499867
LSRM-A Certificate 2016
Old 10-23-2018, 09:37 PM
DHeal DHeal is offline
Some info for your consideration:
https://cafe.foundation/v2/pdf_cafe_...g%20Safety.pdf
Also, I have found the Mr. Funnel fuel funnel to be difficult to use due to the angle of the RV-12's fuel filler port -- it is also very slow flowing. In 680 hours of using primarily Auto 91+10% ethanol (Yuck!), I have yet to find any evidence of fuel contamination. YMMV.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 870+ hours (as of Jan 2020)!
VAF donation through June 2020.
Old 10-23-2018, 09:42 PM
Above link doesn't work...
EAA #499867
Old 10-23-2018, 10:05 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
The software strips out the %20 characters from the file name Fuel%20Handling%20Safety.pdf
Try using the right button to copy the URL and then paste in a fresh window.
I've looked into this in the past. There isn't really a way to discharge static in a plastic can as the charge builds up on the surface of the liquid. But they seem to be used everyday on boats, bikes, lawnmowers etc without much problem.
Have an extinguisher or fire blanket close to hand seems like a good idea.
Old 10-23-2018, 10:19 PM
Try this link:
https://cafe.foundation/v2/main_home.php
or GOOGLE: Cafe Foundation
Old 10-24-2018, 09:24 AM
tomkk's Avatar
tomkk tomkk is offline
I don't like lifting the 5 gallon cans up to the tank opening so I got a Flo-Fast pump and one of their 5 gallon cans. The pump has a grounding cable that I attach to the aircraft. I transfer the fuel through a Mr. Funnel into the pump can then use the pump to get it up into the tank. Works well and is pretty easy.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK in progress
Old 10-24-2018, 10:28 AM
Sam Buchanan's Avatar
been here awhile
The Fokker warbird wannabe is even more awkward to fuel than the RV-12. Here is my fuel transfer rig that uses a 12vdc Carter automotive fuel pump driven with a retired PC680 battery:
This rig works great, flow rate is one gal/min. Just turn it on, step back and let it it pump. The fill nozzle is an aluminum tube which touches the fuel tank to dissipate static charge (photo shows grounding cable which is no longer used). The valve on the intake tube is closed after fueling to retain fuel in the pump so it won't have to prime next time it is used and eliminates messy drain-back.
P.S. My next-door-neighbor has an RV-12 and commandeers my fuel rig....and has retired his crank pump.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
