DaleB
I've been happy with the charging voltage since installing the John Deere style regulator. I see 14.1 to 14.2 V with the engine running, and it's nice and steady. The battery is happier, all's good. Pretty much.
It's noisy though. I notice a good amount of noise in the headset, a constant low level buzzing hash that varies in tone with engine RPM. Poor filtering, I am guessing. It gets a little annoying, especially on longer flights. I'm not terribly surprised, it's some of China's finest. Probably no worse than Italy's finest. Still... have you guys who are using the JD style regulator noticed the same thing, and have you found a particular supplier that is significantly better? Every ad for that part that I see shows what looks like the same identical part, at prices ranging from $25 to $40 or so. I haven't tried hanging a nice fat filter capacitor on the output yet, but I may try that next.
I had thought about putting the Ducati regulator back in and keeping this one as a spare, but the voltage with the Ducati installed is lower than I'd like to see it.
