Old 01-12-2019, 02:26 PM
Chris Cooper Chris Cooper is offline
Default Mini iPad mount and position
Has anyone found a good place to mount a mini iPad/tablet in the RV3A?
Chris Cooper
RV14 - building
www.vansrv14.uk
RV3A - bought
Old 01-14-2019, 06:42 AM
chris, my thought is find the location that works best for you and your cockpit and then get a mount to finish it off. good luck.
TURBO YES =VAF= Payed Jan2019
RV6-A 5,100+ hrs, R-44 1,600 hrs, Helicycle 320 hrs, gyro sold,35,000 miles flown in 2015
https://i.postimg.cc/tn3h4svg/IMG-3101.jpg
Old 01-14-2019, 07:19 AM
Thanks Ed. I canít get access to my 3 at the moment so I was hoping someone had done this before. There isnít a great deal of space so a knee board may have to be the solution.
Chris Cooper
RV14 - building
www.vansrv14.uk
RV3A - bought
Old 01-16-2019, 12:50 PM
Mycool's Avatar
Mycool Mycool is offline
Im in the process of rebuilding a Rv3 to Rv3a, Im mounting ipad under the Dynon D-180 with a ram mount, also integrating a Dc connection for charging.
US ARMY VETERAN (75th & 1st 509th Airborne)
CFI, CFI-I, MEI, MEI-I, A&P
RV Transitional trainer
RV9A - FLYING
RV3 ďaĒ - Rebuilding
Wheeler Express - Sold
Old 01-16-2019, 02:54 PM
wilddog wilddog is offline
Mine is on a Ram ball mount to the right of the comm in the picture posted above. Not an iPad, but a ifly about the same size. Works well in that position for me in my-3.
Old 01-17-2019, 03:39 AM
Thanks for the suggestions. I don't have a lot of real estate left:
The EFIS is a mockup by the way, it hides the magnetic compass which I will move to the left.
Chris Cooper
RV14 - building
www.vansrv14.uk
RV3A - bought
Old 01-17-2019, 09:26 AM
I remember reading about someone who made a slide-out drawer under the panel for his tablet.
No photos, sorry.
Old 01-17-2019, 01:18 PM
Bdalporto Bdalporto is offline
Second for Ram ball mount. Mine is in a biplane but the panel is about the same size. Ball can be off to the side and using a long mount will place the I Pad where you want. I mounted my ball with a couple of #10 Rivnuts.
Brian Dal Porto
RV-7 Tipper
IO-360A3B6D
Whirl Wind 200RV
Dynon Skyview Touch
Old 01-17-2019, 03:28 PM
Jonathan Alvord Jonathan Alvord is offline
Id mount it in front of a vent to cool it off. When the Ipads (all of them) heat up they can tend to be hard to see, even with the brightness turned up completely.
N122EF RV7A
S40 Prosser Washington
=VAF Dues paid 2019=
Old 01-18-2019, 02:20 PM
Thanks for all your suggestions. iPads overheating isnít normal an issue up here!
Chris Cooper
RV14 - building
www.vansrv14.uk
RV3A - bought
