Go Back   VAF Forums > Model Specific > RV-3
Old 01-28-2019, 02:29 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by Tommy123 View Post
That little wheel in the back you guys are so proud of doesn’t seem to be very popular with modern aircraft designers since 1940.
They don't care much for reciprocating engines either.
As for the tip-over vs. slider debate, I went went with the tip-up for the same reason you are going with a tip-over. Besides, if you go upside down, the slider will probably jam and you won't be able to get out because there is structure in the way.
I do believe there is a behind the head roll bar that is available for the -3. If not, make one.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-30-2019, 01:05 PM
smokyray's Avatar
smokyray smokyray is offline
Default Feeling tipsy...
Originally Posted by David Paule View Post
RV-3s have the choice of a slide-back or a tip-over canopy. On mine, I'm choosing the tipover version mostly to get rid of the viewing obstruction of the windshield frame - which to be honest, doesn't seem like a big deal, having sat in two now.
Dave,
Per the above comments, my first RV flight was an early (serial number 5) RV3, a tip-over. I like the Tip Over for the same reason I loved the F16 canopy, no bow=great visibility
As far as flip over/canopy loss, both my RV4 and HR2 have tip overs and in over 2000 hours they never "fell" off and worked very well. !f you lock it, it's doesn't blow open! Additionally I have witnessed and been a first-responder to three RV flip-overs. Two slider 6A's and one Tip over RV3. All three trapped their occupants until we were able to lift them enough to slide/cut them out, one under two feet of mud in a corn field.
Slider vs Tip over wouldn't have mattered.
V/R
Smokey
A proper canopy...tip up with no bow.
PS: The above mentioned RV3 was very light weight, no electrical system and hand propped 0-320 with a Tip over canopy. It broke a record in 78" for time to climb and absolute altitude (21K) that stood until recently for it's class, (C1A).
Old 01-30-2019, 01:56 PM
rv7charlie rv7charlie is online now
There's also the fairly recent thread from Italy where the pilot managed to get the slider canopy open just before touchdown (can't be done at speed), only to have it slam shut on impact.
Old 02-14-2019, 12:19 AM
dlomheim dlomheim is offline
Default VIPER Picture...
Originally Posted by smokyray View Post
Dave,
V/R
Smokey
SMOKEY: I can't believe you didn't post a picture of an AL ANG Viper!!!
