Old 06-24-2018, 01:16 PM
Sam Buchanan's Avatar
been here awhile
Originally Posted by erich weaver View Post
What is your recommended technique for producing a gradual sewage Sam?
Erich
I've done it with pieces of soft, rounded-edge wood in the vice but when I needed to make several of these swages on a different project I made some dies out of aluminum angle. I'll see if I have a photo somewhere.
Edit; went out to the shop for a couple of photos:
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 06-24-2018, 02:23 PM
rv8ch rv8ch is offline
Default cool technique
Thanks Sam, great timing. I've made a few of these that have not worked out, and have recently ordered some more tubing. Thanks for sharing your technique - very clever!
Mickey Coggins
http://rv8.ch
Old 06-24-2018, 06:21 PM
Lars Lars is offline
Adding to the noise...
Decades of working with 300 series stainless steel (what the hangers supplied by Vetterman for my exhaust were almost certainly fabricated from) made me leery of using it for anything that involved possible large amplitude vibration mixed with abruptly changing cross section (cue Sam's swaging trick), sharp edges, etc.
I happened to have a piece of 3/8" OD x .035" WT (I think) 4130 chrome moly tubing lying around from some long forgotten bicycle frame project. Perfect. Enough to make all the hangers I needed. The stuff required heat massage to flatten nicely but 640 hours later no failures. The rust I feared turned out to be a non-issue. My Lyclone doesn't leak much but it dispenses just enough anti-corrosion fluid to keep it at bay.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
700+ hours as of October 1, 2018
Old 06-25-2018, 04:57 AM
i went another route. took some solid steel rod of the same size and flattered the end with a sludge hammer on some steel plate. 5,000 hrs later no problem. stronger is better. impossible to break.
TURBO YES =VAF= Payed Jan2019
RV6-A 5,100+ hrs, R-44 1,600 hrs, Helicycle 320 hrs, gyro sold,35,000 miles flown in 2015
https://i.postimg.cc/tn3h4svg/IMG-3101.jpg
Old 06-25-2018, 11:04 AM
MK77 MK77 is offline
I just had two adel clamps where the hangars attach to the engine mount break.
Matt K.
RV-7 Tip-up - Flying!
XP Superior IO-360 w/cold air sump, Catto 3 blade prop
Garmin G3X
CFI, CFII, MEI
Old 06-25-2018, 11:15 AM
been here awhile
What many of us have done is abandon the "attach to the engine mount" method. Instead, all the exhaust supports (still with isolating rubber hoses) are attached to the engine, usually a couple of sump bolts. That improves the probability the tail pipes will be vibrating in concert with the engine and reduces the chances of broken mounts.
Sam Buchanan
1999 RV-6
Old 06-26-2018, 06:18 AM
DanH's Avatar
DanH DanH is offline
Just a reminder...there are other exhaust hanger designs.
Dan Horton
RV-8 SS
Barrett IO-390
