Old 07-18-2018, 06:03 PM
lr172 lr172 is online now
Default Question on Door Pins
I was going to make some SS door pins. I saw an aftermarket set of pins that used 5/16-24 threaded rods for attachments and that made sense given the instructions calling for 5/16 bolt for setting the drill point on the door posts. As I started thinking about making them, I realized that the ID of the tubes they go into are 5/16, so no ability to cut threads for a 5/16 bolt or threaded rods.
For those that used aftermarket door pins, how are these attaced/secured to the 7/16 tubes used in the doors?
N64LR
RV-10 in progress
Old 07-18-2018, 06:16 PM
The pins are threaded for studs. You screw a stud into the pin, then shorten the factory rods and tap them to match the stud. You attach the pins by screwing them into the rods.
Make sense?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-18-2018, 08:00 PM
Make sense?
That is what I thought. However, the example that I saw said they used a 5/16-24 stud. The tube that Van's supplies has an OD of 7/16 and an ID Of 5/16. You can't tap a 5/16 tube for a 5/16 stud. What am I missing?
N64LR
RV-10 in progress
Old 07-18-2018, 08:31 PM
All I can tell you is whatever stud they provided (I didn't measure) required me to tap the Van's supplied aluminum tube. Once I did, everything was hunkey dorey. ;-)
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-18-2018, 09:24 PM
I wonder if it was a 3/8" stud. I was a little afraid of using that, as it only left me around 1/32" of meat on the tube at the major diameter of the threads. The planearound site said they ship with 5/16 studs, but I can slide a 5/16 stud right into the stock tube without tapping it. I suppose I don't need a great deal of strength on the tube, as the steel pin will be fully seat in both the door and pillar holders, so it is doing all of the holding of the door.
N64LR
RV-10 in progress
Old 07-18-2018, 09:35 PM
Yep. The only load on those threads should be the tension when you retract the pins. Any compression loads should be transmitted through the adjoining faces of the pin and tube.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-18-2018, 11:35 PM
I have seen a couple of references here now to the 5/16" threads. I am beginning to wonder if Vans changed the size of the tube used. I wonder if the walls used to be thicker than .063, which would have allowed you to cut 5/16 threads. I remain concerned about using 3/8 threads.
Does anyone know the OD on their push tubes?
N64LR
RV-10 in progress
Old 07-19-2018, 09:53 AM
Strasnuts Strasnuts is offline
Default SS pins
Larry,
I make the PlaneAround stuff. If you have any questions on sizes give me a call. I'll be happy to share them. 801-580-3737.
A&P RV-10 Flying 950 hours
SuperSTOL Flying 100 hours
Old 07-19-2018, 11:31 PM
Originally Posted by Strasnuts View Post
Larry,
Enjoyed speaking with you and thanks for the help!
N64LR
RV-10 in progress
