Old 10-30-2017, 11:24 PM
SeanM SeanM is offline
Default Riveting F-1055 rudders stop skin stiffeners
Emp page 10-20 Step 7- "... Rivet the stiffeners to the F-1056 rudder stop brace using AN470AD4-4 rivets"
I am not sure how to reach these 4 rivets. My double offset set isn't long enough (or offset enough) for my gun to clear the longerons. The squeezer can't reach it either.
How have others gotten to these rivets? I see Aircraft Spruce has a 10-1/2" length 1/8" straight set. I'm thinking this may be the way to go--if it'll clear the longerons that is. I figured it would be wise to ask here first. Thoughts?
Pictured are the holes in question. I have rivets in two of the four the holes, one on each side:
Old 10-31-2017, 07:55 AM
rvanstory's Avatar
rvanstory rvanstory is offline
If I remember right, I was able to get squeezer on two inside rivets. Blind riveted the other two for reasons you mentioned.
Randy Vanstory
Building RV10
N783V - Reserved
Flying Mooney M20J
Emp Kit Completed, Tail Cone Attached, QB Wings delivered and starting Fiberglass Top.
Dues Happily Paid 2019
Old 10-31-2017, 11:47 AM
BrianDC's Avatar
BrianDC BrianDC is offline
Not sure if different squeezers have different dimensions, but I was able to get my squeezer onto all of those rivets using a 1-1/2" yoke. (It came with the squeezer kit I got from ATS). It was tight and remember that trying to trigger the squeezer while holding it upside down was "fun" but it worked.
Not sure if that really helps your situation out however.
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - in progress
RV10builder.com
PPL / IR - KVKX / KHEF
Old 10-31-2017, 02:02 PM
flion's Avatar
flion flion is offline
I had to go back and look at my log. A friend had an 'alligator' style pneumatic squeezer, which did the trick.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 10-31-2017, 02:10 PM
RandyAB RandyAB is offline
I used a hand squeezer. Being #4 rivets it took a bit of work to squeeze them but it was doable.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 11-02-2017, 01:00 PM
ppilotmike's Avatar
Pneumatic squeezer.
Mike Rettig
EAA Chapter 301 www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 11-03-2017, 08:53 AM
AZSteve053 AZSteve053 is offline
How about an Alligator rivet squeezer - comes in pretty handy lots of places - borrow or rent if not wanting to invest.
Old 11-03-2017, 10:42 AM
Alligator squeezers seem like they could be super useful, maybe just a tad pricey though. I would like to add one to my wishlist but will need to research them a bit more, any recommendations?
No way I can get my existing bulky pneumatic squeezer in there. The straight set from AS should arrive today and I will give that a shot. If that doesn't work I may look into a hand squeezer or just biting the bullet and getting an alligator squeezer.
Old 11-03-2017, 11:51 AM
I have both a pneumatic and a hand squeezer. There have been a few places in the build so far (trim tab hinges (ie: AN3 rivets in tight places)) where I prefer the hand squeezer. It gets into tighter places and it's easier to control overall. AN4 rivets take a bit more muscle but can be done in small batches. It will be much less expensive than adding another pneumatic squeezer.
Randy P.
1st time builder
2017 dues paid
