Old 10-15-2017, 02:07 PM
RandyAB RandyAB is offline
Default 11-2 Detail C questions
What is 5702-95-30 pointing to both sides of the inside gap referring to?
Also, I'm measuring about .06" on one side and .03" on the other which basically translates into one regular thickness washer and one thin washer to close the gap. Any tricks on getting the washer into such a tight space? Glue with cyanoacrylate to the side of a thin scap of sheet metal and use that to place the washers?
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 10-15-2017, 02:14 PM
I answered my first question somewhat. I see that it refers to washers that are 1/4" ID and 3/4" OD. I'll have to check their thickness to see if there is enough room in the small gap on both sides.
Randy P.
1st time builder
2017 dues paid
Old 10-15-2017, 03:08 PM
rocketman1988 rocketman1988 is online now
Default These!
Washer Wrench Set...worth every penny!
http://www.cleavelandtool.com/Washer.../#.WePAGUy-K3c
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-15-2017, 03:18 PM
Nice! Thanks Bob!
Randy P.
1st time builder
2017 dues paid
Old 10-15-2017, 06:48 PM
DRMA DRMA is offline
The 5702-95-30 is referring to an AN4 ID washer with a 0.753 OD that Van's provides with the kit using that part number. There is one placed on each side, with additional AN960-416 AND/OR AN960-416L washers added to fill in the remaining gap.
As I recall, getting these in was difficult but I didn't have the washer wrench set at the time. I've since bought one and it does help a bunch. At the time, I took a very fine thread and passed it through the 5702-95-30 and the AN960-416, tied it to the washers, and used the thread to lower and maneuver the washers into the space with one hand while slowly pushing the bolt through with the other once the washers were in place. A very frustrating but eventually successful process.
You can use the above method for now, but buy a set of the washer wrenches for the future difficult installations - You'll be glad you did!
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 10-16-2017, 09:36 AM
flion's Avatar
flion flion is offline
Another technique is to use fuel lube or its current iteration to stick the washers in place.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 10-16-2017, 10:00 AM
Default Messy
That fuel lube is some messy stuff...
Bob
290 HP Barrett Hung
Wiring...
