Old 09-16-2017, 08:33 PM
papamike's Avatar
papamike papamike is offline
Default Headset jack location?
I'm getting ready to install Stein air vents in my RV7 slider. I know this is a possible location for the headset jacks as well. Any body have any advice as to whether this is a good spot, or where else I should put them? Any issues with the jacks being so close to the skin at that location? Any interference with future interior sidewalls?
Pete Miller
RV-7 Firewall Forward
N174PM (reserved)
Plano, TX
http://smilinpete.com
Old 09-16-2017, 09:04 PM
tgmillso tgmillso is offline
Hi Pete. I guess it depends on what size vents you are using, and how much panel space you have available. I used the large vents and placed them on a sub panel that mounts to a bracket riveted to the fuselage side skin, and also to the bottom flange on the instrument panel. I don't have any good photo's in my log, but will get some this afternoon. I made this panel large enough to enable the install of the vents, two jacks and one push-pull cable on each side (left side for park brake, right side for firewall heater valve). The panels were triangular so that there is no interference with your knees. I placed the jacks here as there will be a pocket underneath to take any ANR battery packs etc.
The downside about this approach is the you will need a few more rivets down the side of the fuselage where the standard bracket goes, and you will need to make sure any bracket matches the fuselage curvature well.
Tom.
Old 09-16-2017, 09:13 PM
Larco Larco is offline
This is one of probably 115 different opinions of where to put the jacks. :-)
Old 09-16-2017, 09:26 PM
The jacks on my RV-6 are on the outside armrests, fairly close to the bulkhead that runs behind the seat. That helps keep the cords out of the way. The downside (if there is one) is that access to the jacks is more difficult than if they were panel mounted.
But... This ain't a rental airplane where you'll be plugging in your headsets every flight and removing them at the end of the flight. My headsets stay plugged in for months at a time...
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-17-2017, 03:56 AM
Here's my location. The outboard two holes are for the jacks, and the inboard hole is for the parking brake cable. The vent mount (sized for the large Steinair vents) is attached to the sidewall bracket using three NAS1801 #8 screws into nutplates (the NAS1801 hex head is a favourite of mine if space is restricted and you have to get a socket on things). There is also one screw that attaches the bracket to a nutplate on the flange of the instrument panel. I hope this helps, and as the other posters have indicated, there are a multitude of options for this one, all with their positive and negative aspects.
Tom.
Old 09-17-2017, 04:09 AM
control control is offline
My view is that it is even more important that the cords are not in the way when you remove and hang your headset somewhere, than when you are wearing them.
So I suggest you think about where they will be stored first, a hanger on the outer side walls below the panel or behind or between the headrests or.... and let that influence where you put the connectors.
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 09-17-2017, 04:16 AM
Excellent point. Like Mike Seager's RV-7, I fabricated a bracket to hang them on the F-902 bulkheads each side of the forward cockpit. Just be sure to enable enough clearance for the 2" scat tube. I didn't, thus I'll have to make some more that are a little lower so I can still attach them to the same nutplates I have already installed.
T.
Old 09-17-2017, 09:37 AM
flion's Avatar
flion flion is offline
My -6A jacks are on the seatback channel between the seats and I have never regretted this position. I'm not a big fan of cords in my lap. I can reach the jacks in flight (with the shoulder straps loosened) but have only needed to do so once. Both the Bose and Lightspeed controls end up between the seats (the cord length is just right for that). On the -10, I'm going with the jacks in the Aerosport center console and the rear jacks on the rear of that console. The best thing about center jacks is that I don't have to struggle with cords getting into the aircraft.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 09-17-2017, 09:57 AM
gasman gasman is offline
On my 6A, my seat backs are only 12 inches wide so I can operate my manual flaps with ease, but I can also reach back behind the seats. My jacks are located right behind the pilot seat in a small box on the floor held there with velcro. I can reach them if needed but it keeps the wires behind the seats, and the headsets stay there also till needed. I might make brackets to hang the headsets on the seatback. Wiring to that location is a bit of a pain, but I would do it again.
VAF #897
2019 =VAF= Dues PAID
Old 09-18-2017, 06:30 PM
Mount them where you can easily reach them in flight. The first thing you need to do in a lost comm situation is to jiggle those plugs!
I like the stock Vans location. The headset wires just tuck neatly alongside the seat.
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2019
