GRT VDO pressure senders
vluvelin
Does any body know how to id If pressure sender is 80 or 150 psi
I didnt find any reference on sender case to part numbers 360003 or 360004
Thank you
Not sure if this helps you, but on my 30 psi model, the hexagonal portion right above the threads was stamped '2 BAR' which is ~30psi. Maybe yours has a similar marking?
Chris
These are the markings of the 80 psi fuel sender from VDO (1/8-27NPTF, or VDO#918-360-003) - they are roughly $35 on EBay.
150psi unit is marked '0-10bar'.
I purchased mine through Jegs with a part number of 360-004.
The packaging has an additional number 'V1521001040D' - not sure what this is.
