Old 11-18-2019, 09:42 PM
Dugaru's Avatar
Dugaru Dugaru is offline
Default Crumbling backshell
Electrical gurus:
I noticed a little gray fleck of plastic on the floor of my RV-9A. Investigated and discovered the backshell of one of the d-sub connectors on my EIS 4000 was crumbling at the screw locations. Not a great photo but it gives you the gist:
https://share.icloud.com/photos/0BIl...GHV78zK_8iOzmg
This is presumably the d-sub connector that was installed by the builder back in the 2005-2007 time frame.
And there's more: the crumbling pieces (one chunk fell off into my fingers when I touched the connector) felt slightly oily, as if they had just the tiniest misting of a really light machine oil.
I didn't see any obvious signs of staining, leaks, etc. anywhere behind the panel, but I didn't do any really serious spelunking yet.
What's going on here, do you think?
Also: what brand/kind of backshell should I replace it with? Given the joys of rooting around behind the panel, I'd like something as durable as possible!
Thanks in advance for any ideas.
N929JA, 2007 RV-9A
Based W96 - near Richmond, VA USA
2019 Dues Paid
Old 11-18-2019, 11:48 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default DB-25 backshell
What you need is something like this:
https://www.amazon.com/Metalized-Pla.../dp/B01NAPY8I2
You can get them in many places, but I'd plan to pull the panel and see what's going on. Sounds like there is more to this story. Will be a great experience for you if you have not done this before.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-19-2019, 05:36 AM
noelf noelf is online now
SteinAir and Aircraft Spruce both have backshell kits for these connectors.
Noel
RV-6A N6NF
tip-up
flying
Old 11-19-2019, 06:38 AM
chaskuss chaskuss is offline
Default Replacing plastic with more plastic??
Mickey,
Your link shows more plastic housings. How are these better than what he is having problems with? Are you using these items with success? Just asking.
Charlie
Old 11-19-2019, 07:16 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Buy them from Stein and be done with it. If possible, try to get the ones that have slot ends on the screws so you can use a small screw driver to help reach in tight places.
Amir
RV-7 - My Ferrari in the sky
RV-10 - Partnered with a good friend
Supporting VAF since the first visit
Old 11-19-2019, 08:20 AM
Dugaru's Avatar
Default Thanks to all
I really appreciate the info. My working theory is that, unrelated to my degrading connector, I may be getting just a hint of water behind the panel. Flew through some rain lately. In any event, I need to chase that down as well!
N929JA, 2007 RV-9A
2019 Dues Paid
Old 11-19-2019, 08:25 AM
rv8ch's Avatar
Default DB housing
Originally Posted by chaskuss View Post
Mickey,
Charlie
Hi Charlie, yes, I've used plastic, "metalized" plastic, and metal. For back of the panel to connect to the EIS and EFIS, there's not a lot of difference between them. The area behind the panel should be very much a "shirt-sleeve" environment.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-19-2019, 08:27 AM
rapid_ascent rapid_ascent is offline
To me it just looks like the attachment screws were over tightened and probably cracked the backshell. This type of plastic is pretty brittle.
Ray Tonks
2020 Donation Paid
Titan IOX-370 on order
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
