Old 05-14-2015, 08:34 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by carrollcw View Post
85 lb baggage capacity with full tanks and the wife and me (320 lbs). Looks like no acro with a passenger though . Oh well!
Do not figure baggage allowance with full fuel. You will seldom land with full tanks. Baggage allowance should be calculated with minimum fuel for C/G limits.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 03-14-2016, 07:34 AM
kblack kblack is offline
Default Unpainted taildragger
Empty = 1,055 (491 RW, 495 LW, 69 TW), 80.98"
RV-7 slider, unpainted, no gear leg fairings or wheel pants. Minimal interior, but I plan to only add front and baggage carpet. Barrett IO-360-X, 8.5:1 (180hp) with Superior sump, Catto 3-blade, Vetterman 4-pipe exhaust, SkyTech starter, and backup alternator on accessory pad. Battery is Van's standard firewall mount. Dynon panel with GNS-430W.
I expect paint, carpet, etc to add 30 to 40 lbs and move the CG further aft. Right now, I would be limited to 79 lbs baggage with standard 170 lb pilot and passenger, but T/O gross would only be 1,726. Soooo, I will likely install a 15-20 lb crush plate. Looks like this will get me close to 100 lb baggage with 2 adults at both fuel extremes. I also plan to fabricate a storage locker for the tie-down kit (about 12 lbs) as far forward on the center floor as practical.
Kliff Black
RV-7 QB (N74KB) - First Flight 3/5/2016
Old 03-14-2016, 04:09 PM
MikeyDale's Avatar
MikeyDale MikeyDale is offline
mains 522 and 529
TW 72
Empty CG 81.25
Hartzell CS, IO 360, Full Classic Aero Interior, Paint
Not too bad but it still eats on me! I splurged for the CS and my wife and I still cant carry 100 lbs and land with less than 30 gal! I need to find a lighter TW and start polishing that paint on the tail!
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
First Flight https://www.youtube.com/watch?v=QqgxhWH3pqA
Build Blog http://mikesrv7.blogspot.com/
Dues Paid
Old 08-28-2016, 08:11 PM
bret's Avatar
bret bret is offline
Do we need to put together a detailed equipment list, and their appropriate calculations for the W&B? and how detailed? canopy shade open close, hand held ect?
2018 gladly supported
Old 12-06-2016, 09:21 AM
Raymo's Avatar
Raymo Raymo is offline
Bret,
Slow response but my 2c is that you do not need a detailed equipment list with locations/weights/arms but it would not hurt if you did. Changing things down the road would be easier to re-calculate.
Keep in mind that any change under 1 lb does not require a change to W&B.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 02-02-2017, 01:07 PM
Raymo's Avatar
My numbers now that I am flying rather than building. No wheel pants or paint at this time.
RV-7A
L = 410
R = 408
N = 275
CG = 80.19
Total = 1093 = 707 usable load
I installed a 20 lb Saber plate to compensate for the 12 lb Catto 3 blade prop. Also have the Anti-Splat Nose Job 2.
Ray
NSDQ
Old 03-09-2017, 10:08 AM
Chattin35 Chattin35 is offline
Originally Posted by rockwoodrv9 View Post
Im thinking the same thing for the 9A I am building. I want a Catto and the 6800 battery, but I am afraid I will not be able to carry the baggage I want to. I think it is more of an issue with the 7, but what are people doing to keep the CG in the right place for baggage? A little more weight up front makes a big difference.
Rocky, I think the -A models have fewer aft CG issues than the taildraggers. I wouldn't stress about it. There are many ways to adjust.
Old 03-09-2017, 10:20 AM
Default Be careful with this one...
Originally Posted by Mel View Post
Do not figure baggage allowance with full fuel. You will seldom land with fuel tanks. Baggage allowance should be calculated with minimum fuel.
... Except for emergency returns. Understand the risk you're taking doing this. RV's can't dump fuel -- unless someone has a crazy mod .
Old 03-09-2017, 10:34 AM
Mel's Avatar
Mel Mel is offline
My primary concerns are for C/G limits. You are correct that it IS a factor for gross weight.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 03-13-2017, 04:53 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
IO360, 2005 catto 3 blade
Here's my morphed 7A to 7 data
7A CG = 81.88, empty weight 1081
7 CG = 81.11, empty weight 1065
Since I will be installing the landoll ring, I was looking at the data today, my cg moved forward on the conversion.
The 12# ring will help, but I will also keep my lead scuba bean bags on my inside firewall. I created a dam to hole them forward.
Dan "RoadRunner" Landry
Morphed RV7, N20DL, PNP Pilot
1050+ hours, hit 1000 enroute to Oshkosh
2017 Donation Paid
