anyone have recommendations for removing from the canopy, what appears to be paint overspray ??
Not sure what chemicals are ok,..and not ok with the canopy material... and what might cause more harm than good. Also worried about the paint specks ending up causing scratches if they were to be popped loose. And wondering if the paint might have already caused damage with little "divots" where it "bonded" to the surface
I'm trying hard not to go ballistic on this,,..and sure hope someone has figured out how to handle this without trashing the canopy. Until now,... it has been essentially clean and scratch free. (ok,.. not counting that little piece you knock out before you put the canpoy guides in,.. or get real careful setting it down)
ah the joys of sharing a hangar with several planes and a maintenance bench...
Thanks in advance!
Thanks in advance!
