Aerox sticky valve
Jerry Carter
I have the Aerox oxygen tank with the oxysaver cannulas. I've had problems with the little ball sticking at the base of the indicator reservoir, effectively occluding the flow of oxygen. This has happened with both of my cannulas, so I suspect that this is a common problem. I just got off the phone with a gentleman at Aerox who told me he had heard of this happening "once or twice." He said that debris or moisture could cause this to happen and offered to inspect them if I would return them. If you have this system, I would suggest a careful preflight inspection to determine that this valve is operational, especially if you plan to be at an altitude where oxygen is essential. Storing the cannula upside down, so that the ball is not wedged into the base might also be a good idea.
Aerox flow indicator
Also remember to put the valve (and floating ball) somewhere you can see it in flight. It is a visual check that oxygen is indeed flowing. Very foolproof and simple. If it is stuck, tap it. When upright, the flow will keep the ball from settling back down. That is as intended....
