Stockmanreef
I received my panel from SteinAir and I will have to say that it looks great. I have a question about the install. I have a 750 with a gam 20 stacked on top and the autopilot under it. I current have the main WH from all the avionics running in the area between the panel and sub panel and run through the big holes in the in the "braces" that separate the pilot and co-pilot side and and under the 750 and behind the autopilot. The wiring to the 750 and gma20 run out the back of the sub panel.
All the the holes and metal edges I have lined with the grommet that ACS sells for lining holes where wires run through.
https://www.aircraftspruce.com/catalog/appages/grommetedging.php?clickkey=4582
My question is: Is this OK? Or should I pull all the remote stuff out and run the WH along the bottom edge of the subpanel. With the current situation, wires would lie on top of the GTR-45 rack on the co-pilots side.
Again, maybe I am over thinking this.
I would post pictures, but I need a free place to host all my photobucket photos got squashed. Maybe I will post a video to my facebook page later tonight.
