I had someone bring me a plane for a condition inspection and he had a Lasar ignition system and the Lasar timing synchronizer. This is the first time I have had to time a Lasar. The non sensor mag seemed to work fine with the timing synchronizer. When you turned the prop or mag there was a clearly defined point where the LED would turn off. The sensor mag did not have a clearly defined point. As you turned the prop the LED would flash on and off many times as you approached the timing point so there was no clearly defined point to set it.
I am assuming that this indicates a fault, but I don't know if it is a fault with the timing light or with the mag. I am pretty sure I did get it in the right place and the mag drops are both the same, but I sure would like to know it is right. Has anybody seen this indication before? I asked a few IAs I know, but neither has done a Lasar before.
