Oops Pop Rivet???
BGordon
Just a quick question for the brain trust. I accidentally over countersunk the rear spar on the left elevator (where the trim tab mounts), the hole are to big and the standard rivets have a lot of play. I plan to run a #30 bit through and then use an oops rivet along the spar. My question comes when I get to the four pop rivets at the end of the spar. Does anyone know what pop rivet can be used with 1/8 shaft and 3/32 head.
Brandon
The blind oops rivet is...
CR3214-4-?
The question mark is the grip range in 1/16"
The shortest they go is a -2, but the seem to work well in as little as an .050 pile-up. They are at least as strong as a 426ad3 rivet.
Tech Page http://www.gen-aircraft-hardware.com/images/pdf/cherry.pdf
We do have packages of both 10 or 100
To Purchase Go to http://www.gen-aircarft-hardware.com then navigate from left side box, Rivets, Blind rivets, Cherrymax, (then choose your item)
If you have trouble or questions call me Monday.
