Old 06-18-2018, 03:10 PM
Stewie Stewie is offline
Default PRC substitute?
I have had a lot of headaches with PPG trying to source PRC to European clients and am wondering if anyone out there has used another two-part polysulfide similar to ProSeal B2 that they were happy with? Any suggestions appreciated.
Eric
Eric Stewart
=VAF= dues paid 2016
facebook.com/TheSR1Project
Old 06-18-2018, 03:43 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
I've used the Chemseal products from Spruce with no problems, other than the usual sticky mess ones.
I think the key is simply to buy to the correct specification whoever the manufacturer is. From the PRC document -
Meets requirements of specifications AMS-S-8802 formerly MIL-S-8802,
We typically use type II, Class B, with the following number giving the working time in hours (usually 2).
Just buy to the specification, the Chemseal product meets the same spec.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-18-2018, 03:57 PM
RV6_flyer's Avatar
AND I have also used the 3M AC Tech AC-236 product. As Gil says, they are all the same spec but different manufacturers.
Last time I purchased, the 3M AC Tech was the lowest cost in the U.S.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-18-2018, 04:36 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
In the UK Silmid is a major supplier with a good selection of PRC sealants.
I suspect there are other suppliers in Europe as it is commonly used in the aerospace sector.
penguin penguin is offline
PR1440
https://www.silmid.com/sealants/fuel...138-msrr-9144/
Its twice as expensive as the stuff we used for 30 years (I think that was PR1412), but that has fallen foul of the REACH regulations.
Pete
Old 06-18-2018, 05:04 PM
az_gila's Avatar
Smile
Originally Posted by penguin View Post
PR1440
Pete
Yes, same spec as mentioned above...
http://www.ppgaerospace.com/Products...k-Sealant.aspx
Gil Alexander
Old 06-20-2018, 11:52 PM
Default Thanks
That makes sense to just buy according to the spec. Very helpful everyone, thank you!
Eric
Eric Stewart
