Old 06-15-2018, 06:03 PM
DaveO DaveO is offline
Vern,
I like what you did, had I not already built mine and had seen your earlier I might have done something like yours.
I can tell it would be extra work.
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 06-17-2018, 12:21 PM
BillL BillL is offline
Default I followed this technique.
Originally Posted by vlittle View Post
Scroll down here to see what I did. A lot of work.
I used some #6 aluminum stand offs, a stainless stud into a nutplate, then a CS screw on the plate itself. Yes, quite a bit of work to get the plate fitted and flush, but looks great afterward. Use 3/32" CS pull rivets for the nut plates, easier.
Out of concern for safety I did a lot of testing on the fasteners. Did you know that a nut plate/stainless all thread/aluminum standoff can take 50 in-lb before it plateaus? And the flat head screw plateau is at about 30 in-lb - ? I used blue loctite and torqued to 12 in-lb.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
