Mike Armstrong
I?m about to remodel my home and that includes adding on an attached garage (shop ). Living in So. Cal. the available property space to build on is limited (read: the large spacious shop I really want aint gonna happen here) so the dimensions of the garage will be 20x22ft. I?m still in the planning stages so what I need, knowing this will be a shop specifically for building a kitplane such as an RV (-12?), is what kinds of things I should be telling the contractor to include in the construction. I would like this shop both wood and metal kitplane construction friendly for the option of selecting different kit projects in the future. I?m not needing a list of shop tools (yet) as much as what needs to be included in the construction of the shop itself. I would really appreciate advice from those that have homebuilt as to what kinds of things are a ?must have? or ?nice to have? for the homebuilders shop to have built in such as,
1) Sound deadening materials in the walls and/or roof? (riveting noise ect.)
2) Electrical requirements? (access, machine/tool, arc welding ect.)
3) Ventilation? (paint, chemicals, sealants ect.)
4) Lighting? (overall)
5) ?
What would you include in the construction of your shop if you were to do it all over again? What is the one thing or things that you wish you had already built in? Thanks
Mike
5) ?
Mike
