Old 07-31-2018, 05:48 PM
smithflys23 smithflys23 is online now
Default RV8 BatteryMinder
I did a search, and saw one thread that referenced a firewall mounted battery. That is not applicable to my situation.
Iím curious to read what you guys have come up with for a battery charging soulution. My battery is mounted behind the rear baggage area, and is enclosed. Meaning, I have not have fabricated a trap door to access it without doing a lot of unscrewing. Any help,is appreciated!
Old 07-31-2018, 06:22 PM
Carl Froehlich's Avatar
Many ways to do this. Simplest is a standard power jack mounted on the baggage compartment shelf, panel or other convenient spot with a 10 amp breaker wired to the battery(s) or master solenoid(s).
That said, try to never use it. I talked to an RV-14 builder today who just distroyed his third PC-680 battery in two years by using a battery minder. An Odyssey battery retains 90% of its charge sitting idle, so the 1960 concept of trickle charge makes no sense.
My rules for airplane batteries:
- Never charge a battery unless there is a specific reason.
- Never leave a battery charger on a battery unattended. Keep a volt meter on the battery during the charge and remove when terminal voltage gets to 14.3 or so.
- If you run a battery flat, replace it - period. You have damaged it and now do not know what reserve capacity it can provide. Us it in law tractor or such.
- Never run a panel on a battery with a battery charger connected. There are very nice 30 amp power supplies at less than $100 to do this. I have a jumper behind the panel to connect the power supply when I want to run the panel for extended periods of time on the ground. This can also charge the battery just like the alternator if desired.
Old 07-31-2018, 06:47 PM
Champ's Avatar
Champ Champ is offline
+1 on Carl's points. I did put in a trap door for easier access to battery, strobe power pack and ELT. Also ran the Odyssey charge cable thru a grommeted hole for quick plug in if I ever need it.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2019 Donation In
Old 07-31-2018, 06:50 PM
The batteries in my 10 were behind the baggage bulkhead, I ran a pigtail from each one through the bulkhead with a split rubber grommet to protect the wire.
Bit of velcro to hold the pigtail end up and out of the way finished it off.
I totally support the prior comment about not charging the battery without need.
Old 08-01-2018, 10:19 AM
The trap door is great, I just wish Iíd have known about it sooner.
Thanks!
Old 08-01-2018, 10:21 AM
My understanding of BatteryMinder, is that it prevents sulfinate? Isnít that what ruins a battery?
Old 08-01-2018, 10:23 AM
Thatís a good idea! Does the BatteryMinder come with the pigtail, or is that something you buy separately?
Old 08-01-2018, 11:03 AM
Came with them.
Old 08-01-2018, 11:06 AM
Sam Buchanan's Avatar
been here awhile
Take to heart the advice to not use a trickle charger with the PC-680. Regardless of whatever chemistry is in play, there is solid field history of AGM batteries dying early due to trickle charging. Fly the plane regularly, leave the charger in the toolbox and you should get excellent service for many years.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 08-02-2018, 07:04 AM
bacstabber's Avatar
bacstabber bacstabber is offline
Default My battery charging solution
Because Iím electrically dependent on my aircraft with my alternative engine installation, I need to ensure that both my batteries are always charged. Therefore, I invested in a BatteryMinder charger, specifically for the odyssey batteries, that is capable of charging more than one battery at a time.
http://www.batteryminders.com/batter...er-desulfator/
I installed two cigarette lighter outlets on the belly of my aircraft near the battery. This is very convenient for plugging the charger into the aircraft. But it has an added bonus. When Iím camping, I can plug my portable electronic devices into the aircraft outlets for charging. Here is my builder log photos of the installation.
http://www.mykitlog.com/users/displa...=148109&row=15
Jack Clark
Pensacola, FL
RV-8A, Flying
N988RV
VAF Dues Paid for 2019
http://www.mykitlog.com/jackclark/
