Hey guys,
New to the forum,
So the G3X do not have dual ADAHARS/batrteries, etc?
It can have dual ADAHRS if you want (can install up to three) and the batteries are up to the builder.
None of which will protect you from a common mode failure so that is why it is still a good idea to install an independent backup solution with a different hardware/software base.
"Let me know if you have any questions."
Why?
Such a layout is typically required for real 2 crew operations in the airlines, chartered world (twin turbo props, etc.) and so on ... Do you have a need for your right seater to have everything identical to you? Do you typically fly with a significant other that is als a pilot maybe?
Just curious ... that's a lot of money and weight and complexity ... I'm wondering what leads you to choosing this setup.
Sure looks gorgeous though! Is that the mid-continent stand-by instrument also? So the G3X do not have dual ADAHARS/batrteries, etc?
That's pretty amazing! Creative solution on locating the A/P panel.
Pahan, welcome aboard the good ship VAF.
Nice looking panel
What is the small back up unit immediately to the right of the key switch?
Define a common mode failure that has occurred in the past please.
I hear this a lot and put Dynon backup in my Garmin panel....but it seems useless to me. Kinda wish I hadn't bothered.
I'd like to see a better place for the AP panel but given the layout I don't know what I'd change to make room for it, it's a head scratcher
Why? Short answer is because I can. It's our company demonstrator aircraft. Also, my wife loves to fly, and use the controls on the right side. She's not a pilot yet, but will be working on it shortly. In the mean time, she does most of the squak codes, frequency and baro changes.
As far as weight goes, it wasn't a significant change from the original steam gauge panel.
Yes, it is the Mid-Continent SAM. The left screen (GDU370) has a backup battery that powers that and the #1 AHRS (GSU73). The Middle screen has its own backup battery which also powers AHRS 2 (GSU25). I also have a #3 AHRS, another GSU25. The SAM is there to alleviate the very, very unlikely possibility of a common software problem between the three screens.
Great setup! What are the annunciator lights for? Left & up of the left screen..
thanks, Igor
