Some fuel distribution issues have been bothering me lately. After matching the injector nozzles, I have been operating lean-of-peak for a number of years with no problems. However, lately I have been experiencing some strange fuel distribution issues. The engine is an AeroSport Power IO 360M1 with Hartzell constant speed prop, Electroair ignition on the right magneto pad supplying spark to the top plugs, and a P-Mag on the left magneto pad supplying the lower plugs. A typical FF/EGT/CHT spread is:
Altitude: 12000
OAT: 58 degrees F
Fuel Flow: 6.7 GPH
CHT #1: 352? EGT #1 -47? (from peak)
CHT #2: 338? EGT #2 -54?
CHT #3: 372? EGT #3 -34?
CHT #4: 373? EGT #4 -32?
At times when initially setting the mixture for lean of peak, the distribution will split, with the #4 cylinder going much richer:
Altitude: 12000
OAT: 58 degrees
Fuel Flow 6.7
CHT #1: 375? EGT #1 -25?
CHT #2: 365? EGT #2 -55
CHT #3: 365? EGT #3 -45?
CHT #4: 385? EGT #4 -15?
The CHT and EGT seem to be in correspondence: EG- the highest CHT cylinder has the richest mixture as shown by the smallest drop from peak. The distribution seems random, and sometimes changes during the flight by itself. Sometimes going back to rich of peak, then resetting LOP fixes the distribution.
Does anyone have any idea what is causing this? Is it a case of dirty injectors or a problem with the flow divider? What might be the solution?
Thanks to all for your thoughts.
Altitude: 12000
OAT: 58 degrees F
Fuel Flow: 6.7 GPH
Altitude: 12000
OAT: 58 degrees
Fuel Flow 6.7
