Old 11-16-2018, 06:53 AM
DonFromTX's Avatar
Another point for a buyer, if you feel that the ELSA is "better" because it was built strictly according to a standard, think again. The day AFTER the ELSA certificate, most any changes you might dream up are perfectly legal and do not have to be in accordance with the ELSA requirements. If you like your lawnmower engine, you can now fly behind your lawnmower engine. After all, it is EXPERIMENTAL!
Retired US Army Officer
Old 11-16-2018, 07:23 AM
DaleB's Avatar
DaleB DaleB is offline
The only reason I would prefer E-LSA as a buyer is the ability to get the repairman certificate and sign off on the condition inspection. Of course an E-AB RV-12 was most likely not built strictly to plans (why else would you make it E-AB?), but one would hope that any deviations would be discovered and discussed during the prebuy inspection. No matter what the airworthiness certificate says, just like any other airplane you really need to know exactly what you're buying -- or be willing to deal with the inevitable surprises.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 11-16-2018, 07:43 AM
Mel's Avatar
Mel Mel is offline
The possibility here is that the builder may already have an engine, prop, avionics, etc., and prefer to use those instead of buying new from the kit manufacturer.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 11-16-2018, 08:02 AM
jnorris's Avatar
jnorris jnorris is offline
Yep, that's the main reason people go amateur-built instead of ELSA on an RV-12. But there is another, obscure reason to go AB. That is to allow the ability to lease the aircraft to another entity. By regulation, ELSA cannot be leased (Ref. 91.319(f)). This is why EAA built the "One Week Wonder" RV-12 as amateur-built, even though it is built strictly in accordance with Van's instructions. The plan is to lease the aircraft to the EAA employee flying club after it finishes it's promotional touring duties.
So, as mentioned before, when one is looking to purchase a flying RV-12, make sure to understand what airworthiness certificate it has, and why. As with any experimental aircraft, each one is unique.
Cheers!
Joe
Old 11-16-2018, 12:56 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Default E-AB vs ELSA
I know of one RV12 built exactly to plans and certificated as E-AB so he could get the repairman certificate instead of taking a 16 hour course. Then he started his 40 hour Phase 1!
Don
VAF #1100, EAA864
-6A bought flying
