Old 11-03-2018, 06:52 PM
Handclutch Handclutch is offline
Default GPS NAC velocity
I am installing a Trig TT21 transponder and using a Garmin 420 W for the ADSB feed. Setup in the Trig is asking for the Navigational Accuracy Category for velocity (NACv) for the Garmin. Says it will be in the GPS installation manual but I can't find it. Has anybody come across it? It will be the same for both the 420 and 430 W.
Jack
Old 11-04-2018, 09:55 AM
Have you tried calling Garmin?
Old 11-04-2018, 10:08 AM
Walt's Avatar
Walt Walt is offline
Jack
10 meters/sec
However for the trig:
NOTE: If the Garmin ADS-B Plus protocol is used then the NACv is set dynamically by the
Garmin GPS unit. This manual configuration item is ignored.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-04-2018, 05:40 PM
Thanks, Walt. The Trig will accept ADS-B Plus - problem solved. (This forum is a great resource!)
Jack
Old 11-04-2018, 06:51 PM
BTW, here in the US the TT-21 doesn't have enough power to meet the US ADSB specs. I presume you checked, it's legal in Australia?
PS I'm using a TT-22 and a G420W, to meet US ADSB-out rules. Works great.
Old 11-05-2018, 05:05 AM
Thanks, Bob. Yes, the TT21 is legal in Oz up to 15000 and below 175 knots. After that you need the TT22 (class 2 transponder). The TT22 transmits at a higher power.
Jack
Old 11-05-2018, 03:11 PM
Interesting. I checked my Freeflight setting, and it is called out at 3 M/sec. I would have expected the Garmin and Freeflight settings would be closer to each other.
