Old 10-27-2018, 12:23 PM
Ron B. Ron B. is offline
Default Voltage regulator plug
Anyone have trouble getting the black voltage regulator plug to lock into position with the locking tabs on the sides holding. The plug seems secure but not by the plastic tabs on the sides but rather by the individual connectors inside.
Thanks Ron
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 10-27-2018, 01:43 PM
lr172 lr172 is offline
Most aftermarket VR's don't have a block for the tang to engage with. The plug uses standard .250" quick disconnect spades and their tension will hold on just fine without the plastic shell being secured.
N64LR
RV-10 in progress
Old 10-27-2018, 02:49 PM
You can remove the plastic shell and just clip the spade lugs onto the VR terminals. Pic below is John Deere AM101406 which has slightly different wiring scheme so plastic shell not used. I've been running this setup for 300 hours with no problems...
Hinckley, Ohio (1OA2)
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 415
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
