Pat Stewart
Started working on my wheel Pant this past weekend. The 12 has an outstanding kit compared to the 8 or 10. Vans needs to incorporate this design into the other aircraft.
I love the RV12 wheel pants and feel they do add a couple of knots to the cruise speed.
That said, it would good if they could modify the fairing with a latched flap or leave a section open so as to both inspect the brakes and make putting air in the tire a lot easier.
I can't modify my SLSA but it would be nice if Vans could adopt any such mods that skilled builders have designed and developed.
If you have to add air every month then you probably have a slow leak (valve stem?)
The leak stop tubes that are used now have a very slow leak down rate. It is common to only have to add air every 4 months or so.
After suffering a flat tire because I taxied on a low tire, I have added a row to my maintenance board to check air pressure every 3 months. They usually just need a small jab of air.
I use tube extensions to check the air. I drilled a one inch hole and filled it with a chrome snap plug. I only remove the wheel pants during the condition inspection.
Do you fly with the valve cap removed? If not how do you get the cap off easily, even with the 1" hole, without removing the pant anyway?
