Rick_A
I just received my interior package from Flightline and I can't quite figure out a couple of things.
The Pilot Side wall of the baggage compartment uses a piece labeled RV-12B3. For the life of me, I don't see how this is suppose to be installed. It almost looks like it was made wrong side out and backwards but even when I put it in that way, it still doesn't fit. (As labeled, the narrow part goes forward which makes it too short)
There is a 1" wide notch in the middle of the bottom edge that doesn't seem to line up with any thing.
If any one has installation pictures, I sure would appreciate seeing them.
Also, can the Upper part of the rear wall (the part with EXPERIMENTAL on it) be installed without removing the fuel tank? I was not able to get it in place without risk of damaging it.
