In answer to a few questions.
Australian bureaucrats will never be happy. They will begrudgingly accept experimental GA. I dont think that their issue is the WAAS position source but the navigation system. They would accept a NAV radio but it seemed a bit silly to install one when they are
decommissioning many of the Aids. When I made my decision the Garmin gps didn't exist.
To the power requirements.
The Rotax engine install manual list 22amps at full power with 20 available at 5000 RPM. It is good practice to only rely on 80% of that for the average or long term number, so 16 amps was the limit. The table below shows the power requirements for a G3X equipped RV-12 with lights on and autopilot and power socket being used. Unfortunately i cant get the table to format correctly however the 3 columns are typical usage, maximum usage and then a column that is either the maximum value or the typical value for things that dont have a maximum.
The gtn 625 is adding an average of 1.8amps extra or 2.8ams maximum. The typical total is still less than the 16 amps.
G3x
GDU 460 (Left 2 2
GDU 460 (Right) 2 2
GTX23 0.8 3.1 3.1 Full TSO reply Rate Unlikley to be responding that frequently????
GEA 24 0.43 0.43
GMU 22 0
GSU 25 0.36 1.8 1.8
GA 26 0 0
GTR 200 0.6 3 3 Shotterm Could be higher
GSA 28 roll 0.36 1.8 1.8
GSA 28 Pitch 0.36 1.8 1.8
Nav Lights 1 2.5 2.5
Landing Lights 2.6 2.6 2.6
Boost Pump 1.4 3 3 1.4 from facet website but 3A fuse?
Accessory Socket? 2 3 3 WAG
Sub Total 13.91 22.6 27.03
GTN 625 1.6 2.8 2.8
GAD 29 0.2 0.2
Total Including GTN 625 15.51 29.83
