flickroll
The #3 CHT on my RV-8 runs high on t/o. If I don't reduce power to 24" - 25" it will go to 420 or higher. T/O EGT's are great...~1200. In cruise the #3 CHT is just fine. The builder of this airplane installed the heater hose hole and flange at the intersection of the #3 cylinder and the baffle, which allows a LOT of air to be dumped overboard without the benefit of cooling the cylinder. Today as a test I placed a piece of aluminum tape over the heater hose hole, and the CHT on t/o is now fine. So it looks like I need to relocate the heater hose hole.
What is the most common place to have the hole for the heater hose air?
