Old 12-27-2015, 11:35 PM
Aero_Octaveus Aero_Octaveus is offline
Default Feedback on wing wiring
Hi Folks, just hoping for some feedback before I start drilling holes in the ribs for my wing wiring. Just a quick idea of what I intend for the plane. VFR/IFR Capable, Dynon Avionics (Skyview) and AeroLEDs - Aerosun VX and Pulsar Lighting.
Left Wing - Dynon Heated AOA Pitot, Vans stall warning (As a backup), Pitot heat controller, Wingtip NAV Antenna and lighting as above.
Right Wing - Dynon autopilot servo and lighting as above.
Any input to things I may be have missed would sure be appreciated.
Garet Hess - Edmonton, AB
RV-7A
2016 Donation Current
http://garetsrv.blogspot.ca/
Old 12-27-2015, 11:45 PM
SMO's Avatar
SMO SMO is offline
You might want a magnetometer out on the end of a wing. As well you might want OAT probe(s) somewhere on the wing (ie inspection panel).
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
Old 12-28-2015, 08:40 AM
wirejock's Avatar
wirejock wirejock is offline
Default Holes
If you go with the plumbing at the location planned, give some thought to how the plumbing will pass the bellcrank. I ran mine through but had to fab a bracket to hold the plumbing lines and keep them away from the bellcrank. Photos are on the "wing" page of my blog. I drew it up. If you want a copy of the drawing, send me an e-mail.
Also, once you decide, drill one with small pilot holes. Clamp an opposite rib to it and match drill. Use these two as masters to clamp and drill the others then enlarge all the holes to final dimension.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-28-2015, 10:05 AM
Default The bracket is a great idea
Yes Larry...the bracket is a great idea. I've looked at your blog and noticed that. PM sent to you with my email address. I would really appreciate the drawing
Thanks Mark...Exactly the kind of input I was hoping for. Now I have a bunch of reading to do on Magnetometer locations
RV-7A
Old 12-29-2015, 09:00 AM
rapid_ascent rapid_ascent is offline
I made a spreadsheet with all of the rib holes and which wires/tube runs where. It is very helpful to keep track of everything. I started using my spreadsheet when I was drilling the rib holes. I have an arrangement like you are proposing. Some holes are not needed in all of the ribs. For example the pitot is in the middle of the wing so those holes don't need to be placed in the outer ribs.
In my case there are lots of wires. OAT was mentioned. I have a couple of those. Stall warner if you are going to put it in is also missing from your drawing. Some people put a nav antenna in the wingtip so a coax would be reqired. Heated pitot power and status wires if you want one of those.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-29-2015, 09:25 AM
Maxrate Maxrate is offline
Garet,
One more thing to think about is the coax run for the nav antenna. Here is how I routed the coax around the the belcrank assembly. On the other wing think about the autopilot servo and other nav antenna if running dual nav/comms.
https://s3.amazonaws.com/expercraft/...99c8dbeea7.jpg
http://websites.expercraft.com/markm...y&log_id=81356
Mark Malone, RV7
Wings complete, SB 14 complied with, fuselage in progress.
N442MM reserved
http://www.mykitlog.com/MikeMike
2017 Donation gladly paid.
Old 12-29-2015, 11:54 AM
Default Diameter of Coax cable
Can those coax cables be routed in the main conduit with the lighting wiring?
Do you know the approximate diameter of the coax, or what size snap bushings are needed for the Nav/com antenna?
RV-7A
Old 12-29-2015, 12:47 PM
On the tip rib, on my RV-3B, the tooling holes are used to line up the ailerons. On the RV-7, that's shown on drawing 12A. I'd recommend keeping the area near those clear.
Also, as other people have suggested, figure out how you'll carry the various things past the aileron bell crank.
Old 12-29-2015, 02:00 PM
Garet,
The normal snap bushings sent in the wing kit will work for running the coax cable like I have in the picture. I ran mine outside the conduit because I heard that others have had interference on their com radios when the coax is too close to the wire runs for the lighting. I don't think it is too much of a problem with LED lights, but just wanted to play it safe.
Mark Malone, RV7
N442MM reserved
Old 12-29-2015, 04:55 PM
wirejock's Avatar
Default Alignment holes
This is an important tip. Don't enlarge the outboard end rib alignment holes. You can drill them later.
Larry Larson
Estes Park, CO
Disclaimer
