Piper J3
I bought braided brake lines from Aircraft Specialty, which arrived this week. Quality looks excellent. So I?m planning the installation and can?t find any information on procedure for bleeding the lines. I?m looking at the plans for the brake system and really have two questions?
The brake system from the pilot?s master cylinders to the calipers is a closed system and not open to the reservoir. How do I bleed air and/or introduce new fluid? I can pump brake fluid up through the bleeder screw at the caliper but if the top end of the system is closed where is the air bubble going to go?
Second question is how to bleed the crossover lines from the passenger brake pedal cylinders to the pilot?s master cylinders with the lines essentially being a closed loop? The passenger side brakes are a little spongy and I think there must be some air in the crossover lines.
