Vern
Yesterday was sobering experience for me!
I got a call from a local A&P/AI who needed advice about an RV-6 that he had been asked to rebuild. I went over to have a look at the RV-6 and was shocked by what I saw, which I share for your safety.
This older RV had just had an IO-360 and blended prop installed professionally at another airport. The owner had flown to our airport (KFFC) and was about to depart for his homedrome. He was in the runup area beside an avionics shop. While performing his runup, his RV engine area burst into flames. Several mechanics rushed out with extinguishers, put the fire out, and got the pilot out with some burns on his legs.
When I looked at the RV yesterday, the tip up canopy, cowl, seats, and all instruments and radios had been removed.
Another mechanic and I surmised that a small 1/8" copper tube from the rear-mounted mechanical fuel pump to a fuel pressure sending unit broke during the runup, allowing fuel from the 1/8" copper line to spray out above the exhaust. This fire only lasted a few minutes due to the quick response by the mechanics. In that short time, every wire and hose firewall forward was either melted or damaged. The entire panel wiring was a melted mess. The interior floorboard 1" black insulation was mostly melted.
Apparently, the fire was like a blow-torch as the windblast from the runup caused the lower firewall and lower cowl exit area to direct the fire down and underneath the RV.
Incredibly, the canopy and cowling are useable. The cowl will need some repairs, but it did not burn thru.
Even though the paint under the airplane did not burn off, and no rivets 'popped' I am concerned that the thick bottom skin in front of the wing spar may need replacing due to tempering from the heat. Certainly the mags, fuel pump, and prop gov need overhauling due to possible heat damage. The firewall seems OK.
My points: if this plane had taken off, the heat from the fire would have really burned the pilot, possibly incapacitating him quickly. His instruments and accessories would have failed shortly. An aluminum airbox would have soon allowed flames inside the cockpit. All this from the fuel spray from a 1/8" line! What would the main fuel line do? (I know-I've witnessed that also)
So, next time your cowl is off, take a critical look at your systems. Everything firesleeved? Have you got any stiff copper lines? Do lines have service loops/slack in them? Any 'stiff' lines used to join the shaking engine and the fixed firewall? All B-nuts tight? All openings in the firewall sealed? Any hidden chafing ready to wear through?
Another area we RV'ers might look at is at our brake lines and fittings which is another potential fire source for our RV design. What about leaking fuel tanks allowing fuel to seep in under our seats and ignite due to electrical devices under the floor boards?
In my AF days I survived a number of inflight fires and explosions. It's no fun when the smoke is so thick and pungent you can't see the fire handles glowing bright red!
We have a fun hobby and we all want to fly safe. Join me in taking another look at your RV to keep it that way!
