jferraro17
Opulence, I has it...
Is there an aftermarket FAB or any other options out there for a vertical intake setup?
Thanks-
Joe
Thanks-
Joe
Thanks-
Joe
I'm just interested in not repairing one every "x" number of hours...I've heard the stories.
I'm also watching a buddy spend a TON of time building his, and thought there might be a better way.
Joe
I don't mean to imply that the standard FAB can't be improved upon or discourage someone from from trying something new but I thought I would relate this story from quite a few years ago.
I was work aircraft parking during the Copperstate Fly-in.
I had just parked two RV-6's that arrived together.
One of the pilots was looking into the exit of his cowling and then began relating the following story.
He had been flying right beside his friend at altitude. All of a sudden his RPM increased (fixed pitch prop) and he began to pull away from the other RV at a pretty substantial pace. He had to throttle back for the rest of the flight for them to stay together.
After landing, what he had found was that his home built airbox had failed and fallen off of the engine and exited the cowl.
Point of post is that their can be a lot more to the design of some of this stuff than might be initially apparent. Over the years I have found that even the smallest little change in something can make a difference that I never would have imagined.
Which says a lot for a by-pass to direct ram air. Filters inhibit air flow, there's no denying it and a filter is not needed in flight.
My filter box will not leave the airplane. It is held together with about 25 rivets and attached to the left intake baffle with 6 #8 screws and plate nuts on a flange. The entire front baffle will leave with it if it does depart.
I just noticed this morning that Joe's situation is with a vertical system, a different issue than what I was addressing, which is a horizontal deal with the intake way up front. I agree, building a box at the intake of a carb can be tricky. There are plenty of such devices available. What I was describing is a simple metal box at the baffle intake connected to the induction intake with scat. It's stone simple except for the cowl being in the way.
As for the "problems" some people have had with with their FAB I have also looked into why. One issue I noted is that on some carbs the mounting plate can not be mounted flat without a spacer due to flashing at the rear edge. Some have notched the plate so much to clear the flashing that it left very little metal near the bolt resulting in a high stress area that resulted in cracks. I filed down the flashing and then used a 3/16" spacer. I believe you will find most RV's have no problem with with the FAB.
.... Consider the snorkel sold by Van's. It is probably not the ultimate in ram air pressure recovery, but it does have some shaping and use of area rules to try and recover pressure. It is far from being just a duct/tube that directs air from one place to another.
...another 200 hours added to the project !
Rgds,
Bill W.
Hey, has anyone done speed runs using the FAB both with and without the filter?
