John Tipton
I'm New Here
Hi Guys
When mounting (-9a QB) the PC680 battery box you have to align with three rivet holes, two one side (no problem) however the side with just one nutplate is missing the rivet (to be drilled out) slightly, what do I do, leave it in and drill the required hole around it, if you take the rivet out you will end up with a 'figure of 8' hole
Regards: John
Regards: John
