Old 11-08-2019, 08:22 PM
Tharpo Tharpo is offline
Default Motor mount question
Looking at an older O-320 that looks like it is gonna take a straight mount.Has anyone used an engine like this on a 4? Is there any reason not to? I'm assuming Vans would would make it if it would work ok.
Tom H.
Old 11-08-2019, 10:41 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Tom H.
Sounds like a conical mount, just delivered an RV-4 conical engine mount to Vanís yesterday so yes if what youíre asking about is indeed a conical engine it can be used on an RV-4 assuming the rest of the engine conforms.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 11-09-2019, 10:03 AM
Default Mount
Thanks Russ
I guess I should have mentioned that there are no letters following the O-320 designation on the data plate. Is that a clue as to its age? I think I was told that, or would that be an indicator of anything that might make me want to pass it up?
Old 11-09-2019, 11:19 AM
Thanks Russ
I have no idea about that, maybe someone else will answer this one.
Russ McCutcheon
Old 11-09-2019, 03:09 PM
jrs14855 jrs14855 is offline
Default Lycoming
No letters is one of the very early 0 320 engines. No cylinder hold down plates under the nuts, so not eligible for high compression, 150 hp max. I think adding the plates requires changing all the studs but am not certain about this. In any event you have a real antique engine, somewhere in the 1954-55 range.
Old 11-11-2019, 02:08 PM
Default Mount
Thanks Lycoming
Went to look again this AM. Passed on it. Looking again.
Old 11-12-2019, 08:13 AM
daddyman's Avatar
daddyman daddyman is offline
Default Straight mount
Tom H.
Tom,
I have an 1996 -4. About 5 years ago I needed to change the mount bushings because they were deteriorated due to age. It was a straight-forward medium sized job.
Mine has an IO-320.
If you are asking about the mounts themselves, they are fine.
I know most folk use conical mounts, but straight mounts are just fine.
Daddyman
Happy Donator to Vansairfore.net
500 hrs in -4
Old 11-12-2019, 08:58 AM
rag rag is offline
I ran a conical mount (also called a straight mount) O320 and Catto prop for many years on my RV4. I replaced the cheap rubber conical mount inserts with Lord conical mount inserts that are "clocked" for engine sag and vibration. I upgraded to a O360 and a dynafocal mount with a Catto prop about 1-1/2 years ago. The dynafocal mount is noticeably smoother. So much better that I would not use a conical mount if I were to build another RV.
