Help with Garmin G-5 installation
chris mitchell
Hi All,
I'd be grateful for thoughts on my recent Garmin G-5 installation in an RV-7. AS part of this work I took the opportunity to install a heated Garmin pitot and to re-plumb the entire dynamic and static system using the SafeAir/Dynon system of flexible tubing and connectors, and a new ASI (with appropriate speed marks for an RV-7 .
We flew an East-North-West-South course to calibrate the new ASI and plumbing with the ground speed taken from the Garmin 430. The results show that the calculated TAS taken from the ASI (corrected for altitude and temp) is within 1% of the ground speed, with the ASI slightly over-reading. So far so good. At least there are no pitot leaks!
However, the ASI and G-5 comparison is much less good.
The instruments agree at 110kts IAS, but at higher or lower speeds - 50kts up to 160 - the G-5 is reading up to 4 kts too low at both the higher and lower speeds.
Which to believe? Well the ASI agrees nicely with the ground speed calculations - so the G-5 is reading low.
I have read and re-read the installation procedure. Can't see anything to help. I did recheck the plumbing, looking for kinks etc but it all looked good. The G-5 is running on its internal GPS antenna - would that make a difference? I can't see that it would. Any other good ideas?
THe original reason for installing the G-5 was as an attitude indicator. I suppose the simple pressure driven ASI and Altimeter are highly unlikely to fail so maybe the easiest thing is to disable the ASI on the G-5, but having plumbed it I'm reluctant to do that. I'd much rather find the problem and fix it.
Many thanks
Chris
Chris,
Why not set up a water manometer to verify your in-flight results?
There are plenty of resources on the web that describe the process and the math involved. Pretty simple to set up and to calibrate your instruments.
My money is on the G5! :) My experience installing G5s and G3X Touch together (GSU 25 ADHRS vs. G5 internal air data) is that airspeed readings are usually within a knot of each other.
Pat, please just walk me through your thought processes here.
The ASI (actually calculated TAS) correlated well with the GPS ground speed over 4 legs. The G-5 is ok at 110 but otherwise is 3-4 kts slow after calculating TAS, compared to the GPS measured ground speeds.
It seems to me that, based on our flight test data, the ASI is pretty accurate and it?s the G-5 at fault.
Maybe I?m just being slow!
Chris
Chris
Chris,
Yes, I agree, it would appear that the G5 is the erroneous one considering your TAS in-flight data. The manometer test will just help you confirm that as well as verify that you don't have a leak. One of the things I like to do as a quick check for pitot leaks is to inflate a small party balloon and slip it over the pitot tube. This usually gives an indication of around 100 knots, but if you leave it on for a while, it should hold pressure. If the balloon deflates, you have a leak. Just a quick troubleshooting technique. Again, it would appear that a leak would affect both instruments equally, but then again you might have an internal leak in one of them. It's probably a calibration issue, but it's worth investigating other causes. Please let us know what you find!
I've found the G5 to work well and compare well with other instruments.
Just to clarify, are you using the four leg spreadsheet available from the test pilot school or similar? Inputs of four ground speeds and tracks derived from four legs on headings 90 degrees apart?
If so I would believe your results, providing you're comfortable with your TAS conversions. I have OAT data available to my systems so my systems have been doing those calcs automatically. I did do some manual calcs to verify them.
Interesting. It may be a case of two opposite errors compensating and giving the right answer. I assume that your flight calibration is accurate. My money is also on the G5 being right.
My guess for the other error is that the static port is a bit off at higher speeds. The static port is pretty fussy with respect to location and surface. The pitot not so much as long as it is within a few degrees of flow, which is usually the case at higher airspeeds.
Two wrongs make a right?
Ron
Feeling a bit grumpy!
We used a 4 leg calibration and the TAS and ground speed (from a Garmin 430) correlated well. For what its worth a transponder check was well within limits ie altitude reported by the LARS station correlated with our altimeter.
Garmin have suggested we do a static configuration which I am loathe to do - we don't have the kit and that instruction is actually in conflict with the manual - which says replace with a known accurate unit.
We are having another session tomorrow. I'll see if the local maintenance organisation has a suitable test kit, so we can at least check the altimeter, even if we don't do the static config.
Inter alia, I am pretty unimpressed with the setup for providing manuals. I don't really understand why I have to plow through the G3X install manual to discover how to install a GMU-11 magnetometer, for example, nor a pitot head. But maybe that's just my irritation showing.
I'll report after tomorrows session.
Chris
So we connected the G5 to reference ASI. Consistently across speeds from 200kts down to 60kts, it was 2-3 kts at least out of agreement except at about 110kts. We have opted to ask for a replacement unit. It?ll be interesting to see how that stacks up.
Chris
My G5 reads about 2 mph lower than ASI. Not sure if either is correct. I do know what my stall speed is on both.
So we connected the G5 to reference ASI. Consistently across speeds from 200kts down to 60kts, it was 2-3 kts at least out of agreement except at about 110kts. We have opted to ask for a replacement unit. It’ll be interesting to see how that stacks up.
Chris
I don't think you're gonna get much better than that as far as accuracy, TSO'd AS indicators limits generally range from 2 at the low end to 7 mph error at the upper end.
If you were to ask me I'd say that's pretty darn good at 2-3kts error, most analog instruments are double that.
And is a few knots really that important?
As far as the altimeter matching your transponders output that's meaningless from an accuracy standpoint.
"As far as the altimeter matching your transponders output that's meaningless from an accuracy standpoint. " I totally take your point!
The altimeter is at least 10 years old, over 550 hours on it. Maybe its time for a check and recalibration if needed. How often should that be done, or is it simply a matter of noting if the indicated altitude on the ground is appropriate for the QNH?
Will report back on the G-5 in due course. THe instrument itself and the kit for intallation with the magnetometer are nicely done.
Chris
It was the G5!
So - we got a replacement G5 unit. Installed it, flew it. Agreed with the ASI within 1-2 kts. So we conclude it was the original G5 unit.
Now we are grappling with the GMU-11. Found some helpful stuff on another thread, so testing is in progress.
Thanks for the comments and suggestions, much appreciated.
Chris
