Does anyone out there happen to have a Plasma III for six cylinder laying about where you can help me trace the wires from the hall effect PC board to the 15 pin input connector?
As I mentioned before, the 15 pin input connector on my Plasma III had to be cut off to remove the engine (firewall hole was too small and I did not want to unbolt the prop to hang the timing sensors loose) so now I have to field install the 15 pin connector.
The installation manual is well written however it does not state the colors of the 9 wires that run from the crank sensor PC board to the 15 pin connector.
If I knew what colors the wires were that powers channel A / B / C then I could deduce the respective black and bare wires.
Inside the single large cable are three shielded sub-cables and each sub-cable has a black wire, a bare non-insulated wire, and then the third wire is the only difference and that would be either a white or green or red wire.
Can you please tell me what color wires are connected to the following pins:
Channel A:
PIN 3 of the HALL EFFECT sensor is a ??? wire and it connects to PIN 4 of the INPUT CONNECTOR (this is a 5 VDC power to the HALL EFFECT sensor and it shares PIN 4 with channel C) If I knew what color wire was Channel A then I could deduce the respective black and bare wires.
Channel B:
PIN 7 of the HALL EFFECT sensor is a ??? wire and it connects to PIN 5 of the INPUT CONNECTOR (this is a 5 VDC power to the HALL EFFECT sensor) If I knew what color wire was Channel B then I could deduce the respective black and bare wires.
Channel C:
PIN 4 of the HALL EFFECT sensor is a ??? wire and it also connects to PIN 4 of the INPUT CONNECTOR (this is a 5 VDC power to the HALL EFFECT sensor and it shares pin 4 with channel A) If I knew what color wire was Channel C then I could deduce the respective black and bare wires.
If nobody has one of these systems opened up or accessible with the prop off then I will sadly need to remove the propeller...Grrr.
Any help would be greatly appreciated!!!
Channel A:
Channel B:
Channel C:
