cdeerinck
The 8 wing spar has only 4 holes. Two are used for the rudder cables. One 4 AWG wire almost fills an entire hole. So just running power and ground from the rear battery uses those up.
I was trying to keep the holes in the side walls minimally used for wiring (pitot, intercom, cockpit lights, etc.). I have two auto pilot servos, elevator trim, and SkyView ADAHRS, transponder, antennae, etc. all in the back.
One of the AP servo wiring, all wiring from the sticks, wing light wires, and heated pitot come from the wings, under the floor, and behind the spar.
I know I can't drill more holes through the wing spars, so how can I run wiring under the floors and end up front? Am I missing something obvious?
