Old 08-12-2017, 11:06 PM
FrequentFlyer FrequentFlyer is offline
Default Targa strip, glue or screw
The targa strip on my RV-7A tip up has decided to separate from my canopy due to heat. It was glued on with Sikaflex but not the UV 295 stuff. The Sikaflex didn't adhere to the plexiglass but is strongly stuck to the aluminum. It lasted about 100 hours.
I'm considering screwing the targa strip to the canopy instead of regluing. Are there a you downsides to this?
Also, the plexiglass is screwed into the frame with counter sunk screws. My thought was to drill back through the existing holes and into the targa strip. Any issues with attaching the targa strip over top of the counter sunk holes in the plexiglass?
Old 08-13-2017, 04:14 AM
Brantel's Avatar
Brantel Brantel is offline
I glued (West System Epoxied) and screwed mine on. It is still there!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-13-2017, 08:03 AM
Michaelpk3 Michaelpk3 is offline
Default Strip
I only used screws, lot a of them! I dimpled the aluminum strip and used flush screws. Then matched the white paint with a white vinyl. It's a little more work, but worth it IMO
Michael Kalfsbeck
Michaelpk3@yahoo.com
N505AT RV-7A based in Sarasota, FL
Donation gladly paid!
Old 08-13-2017, 09:00 AM
bret's Avatar
bret bret is offline
Did the plexi have the primer on it, I can't imagine this stuff separating from it if it was prepped correctly?
2018 gladly supported
Old 08-13-2017, 09:24 AM
I know it is a pain to post pictures here now, but I would love to see some of the targa strip install. I would like to see others before I make mine.
I want to do it on mine. I like the idea of vinyl - maybe the fake carbon fiber vinyl to match my spinner!
I did find a bunch of pictures on google, but would like to see how others have done the install.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 08-13-2017, 09:54 AM
lr172 lr172 is offline
I used a urethane adhesive, but also put in 5 or 6 rivets to hold it on in case the glue separated. Bonding to acrylic is a challenge.
N64LR
RV-10 in progress
Old 08-13-2017, 12:07 PM
I do not know how the plexiglass was prepped as I'm not the original builder.
Old 08-14-2017, 07:54 AM
Snowflake's Avatar
If you haven't cut your canopy yet, another option... Make the split halfway along (front to back) the rear (fixed) canopy bow. The forward part of the canopy will then extend beyond the (moving) canopy frame, and when closed will sit on top of the rear bow. No Targa strip required.
Rob Prior
