Old 08-12-2017, 06:05 PM
Dorfie Dorfie is offline
Default Vx, Vy, Vg
How exactly did you determine these numbers?
I would appreciate some of the numbers that were determined for the RV10.
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2018 dues paid with a smile
Old 08-12-2017, 06:10 PM
bkervaski's Avatar
I'm curious of this as well .. since there are a lot of differences between builds .. I'm assuming you just go figure it out by testing various speeds?
Reserved: N196
Progress: All Kits Done
Old 08-12-2017, 06:41 PM
snopercod's Avatar
Exactly. It's a PITA, but it should really be done for each aircraft. Props, especially, make a big difference. Here's how I found the "best glide" on my plane, and the Vy and Vx are done the same way, only climbing. This is just the 80 KIAS run, and I also did them at 90, 100, and 110. My Garmin Virb allowed me to dictate the numbers into the Intercom and also see the numbers on the panel.
I did this particular test where there were mountains in the area, which was a bad thing; You never know if you are in an updraft or downdraft. Later, I reperformed the tests in a flat area on a windless day.
https://www.dropbox.com/s/dz98ah3d5x...80Kts.mp4?dl=0
P.S. The "landing gear" warning was going off because I was below 90 Kts with my gear up. The "stall" warning was going off because I didn't have it set quite right (yet).
(2018 dues paid)
Old 08-12-2017, 07:00 PM
Ironflight's Avatar
VAF Moderator / Line Boy
The first thing I'd suggest is that you find a local EAA Flight Advisor to chat with - he or she can help coach you through a real flight test program, provide good sources of information on precise flight testing methods and techniques, and probably help you to develop test cards. Box and Vy are numbers you legally must determine for YOUR particular airplane in order to sign it out of Phase 1, and it might take you a number of flights to refine them accurately - it all depends on teh conditions and your ability to fly accurately.
There are a number of good books on flight testing light aircraft - unfortunately, I'm not near my bookshelf at the moment to dig out titles. Check teh EAA store online. there are also FAA Advisory Circulars that will help.
But start with a Flight Advisor - if you're new to this (and it sounds like you are), they can give you a good start in a robust flight test program.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-12-2017, 07:13 PM
Yup
Get your self a copy of Amateur Built Aircraft Flight Testing Handbook AC 90-89B HERE
It is not as in depth as some other references are but it is a good start towards getting familiar what is involved in a general flight test plan.
Scott McDaniels
Hubbard, Oregon
Old 08-12-2017, 09:03 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Thanks.
Johan
Bootstrap to get close, then some additional testing at different weights and CGs to get closer, then development of mathematical models to account for different conditions (weight, density altitude, etc), then additional flight testing to validate the models.
The references listed previously are good starts.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 08-12-2017, 09:24 PM
RV6_flyer's Avatar
Thanks.
Johan
I got my license 35-years ago. Your subject line has Vg in it.
What is Vg? I am familiar with V speeds but not Vg.
Are you trying to determine a maximum gust speed? That would come from the designer
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 08-12-2017, 10:42 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Default Vg = Best Glide Speed?
My guess is the OP meant Best Glide Speed.
(And I got my license more than 35 years ago also. That just means we're getting older! )
Carl N.
Arlington, WA (KAWO)
RV-8, 250 Tach Hours
(Pic)
- Out with the Old, In with the New (Pic)
RV-8, 1938 Tach Hours
(Pic 1), (Pic 2), (Pic 3) - Sold
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 08-13-2017, 06:09 AM
Auburntsts's Avatar
EAA has a Hints for Homebuilders video on finding Vy and Vx: http://bcove.me/8ch18ik8
Finding best glide is similar to finding Vy except you are recording distance covered for a specific amount of altitude loss (say 1000 ft) at a specific airspeed instead of the amount of time it takes to gain a specific amount of altitude (again say 1000 ft) at a specific airspeed.
This is one of those flight tests where the additional pilot program or an autopilot that has an IAS function comes in real handy.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-13-2017, 09:26 AM
ChiefPilot's Avatar
Originally Posted by Auburntsts View Post
EAA has a Hints for Homebuilders video on finding Vy and Vx: http://bcove.me/8ch18ik8This is one of those flight tests where the additional pilot program or an autopilot that has an IAS function comes in real handy.
It's not hard to hold an indicated airspeed to within one knot for 90 seconds of climb or descent given an electronic airspeed indicator and reasonable conditions. I doubt autopilots in our birds could do any better.
