Old 08-12-2017, 04:04 PM
steve murray's Avatar
steve murray steve murray is offline
Default Section 29 ....Help
Every time I do something I think is I think makes sense but is not explicitly stated in the plans I find out I was wrong. (The -10 plans are so much more advanced than my RV8 plans from 10 years ago)
I am in section 29, I have rolled the right mid skin F-1070R using the clamping block (90% satisfied with the results...) but cannot find where I roll the left skin (F1070L) should I go ahead and roll the left skin even though it is not explicitly stated..... seems like I am missing something.... help? When I do roll the left mid side skin....where is it stated.
Steve
RV8 Flying since 2007
RV10 in construction (Fuselage)
Old 08-12-2017, 04:26 PM
leok leok is offline
There is no reason to not roll the F1070R at this point. It is a mirror of the left skin. I could not find the reference in the plans either ... not sure if there is one. I did mine in the same work session to make sure my lessons learned from the first were fresh in my mind for the second skin.
Building my RV-10 since Oct 5th 2014
Flying .. once I figure out how to pay for everything
http://www.mykitlog.com/leok
RV Hotel
Dues paid 2018
Old 08-12-2017, 04:47 PM
Electrogunner Electrogunner is offline
Default Right skin
I called the mothership just the other day about this. Answer ;repeat for right side. They just missed that notation on the drawings.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Finishing and FWF is ongoing
Old 08-14-2017, 12:53 AM
BMC_Dave BMC_Dave is offline
So, how does Vans handle drawing revisions? Are they collecting these omitions or errors?
Old 08-14-2017, 06:29 AM
rleffler's Avatar
rleffler rleffler is offline
Van's post many of the revisions online, although when I was building it wasn't always 100%. I think it depended on how significant the change. i.e. a few typos, or a process/part change.
The RV-10 plans get more terse as you go through the project. The tail kit is very verbose on each and every step. By the time you get to the later kits, they don't walk you through each and every step. They assume that you've learned when and when not to dimple or countersink. In many cases, if you do the right, follow the same procedure on the left.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
