Old 08-12-2017, 10:40 AM
bobnoffs bobnoffs is offline
Default fiberglass primer
hi all, i am done enough with the ''bodywork'' on my cowl that i would like to prime it to pick out imperfections, pinholes . is there a rattle cam primer preferred for glass that will not interfere with a finish coat later on, probably a 2 part finish?
thanks
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying
RV-12 kit as of 9/13
Old 08-12-2017, 10:47 AM
You will probably get different opinions on this, but I would not use a rattle can primer for anything other than interior painting. With good, reasonably cheap epoxy primers and very cheap HVLP guns from HF, why not just do it right? The PPG Omni high build is probably cheaper than rattle can and while it is not the best, it will for sure beat any non epoxy primer from a can.
The one thing about rattle can primers is you can wipe them off with a bit of acetone or lacquer thinner so if you want to test a small part of the cowl, spray, check, then wipe off.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 08-12-2017, 02:27 PM
it is not my intention to use the rattle can primer as the primer coat for my finish coat.i want to put on some primer to see any flaws that hide in the multi color finish of gel, fiberglass and epoxy filler. i expect most of the rattle can primer will get sanded off. i am questioning whether or not i can use it like this and in the end will i have residuals that are a problem.
Bob Noffs
n. wi.
Old 08-12-2017, 03:13 PM
Neal Trombley Neal Trombley is offline
Plenty of automotive primers that will do the job
1 part and 2 part
Any build primer will work just spray inspect and sand.
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 08-12-2017, 03:18 PM
snopercod's Avatar
Default WLS Primer
WLS primer is a "high-build" primer and you can squeegee it on to fill pinholes. It comes in either gray or white. The finish coat adheres well to WLS. I think you have to buy it directly from the company in Los Angeles.
(2018 dues paid)
Old 08-12-2017, 03:27 PM
Using it for a pinhole spotter, it should work great. People use drywall mud to fill pinholes so primer has to work at least as good at it! It will make the flaws show up much better with a contrasting color and final primer will seal anything you put on.
I am enjoying the glass work. It is so easy to think your surface is perfect until you spray a bit of primer. Then when you get the gloss on, it is even worse! Buy lots of sand paper and dust masks!
rockwoodrv9a
Meridian Idaho
O-320 D2A
Old 08-12-2017, 04:09 PM
ok, got it, thanks.
long ago i made a permanent mount outside my shop and a hole thru the wall for my fresh air rebreather and i make myself use it even for any sanding. wear it for a few minutes even with hand sanding and when you take it off you can really smell the dust for a few seconds.
Bob Noffs
n. wi.
Old 08-12-2017, 06:00 PM
snopercod's Avatar
No matter how good your primer is, you will end up with pinholes anyway. I use this stuff to fill them:
Auto paint stores carry the Evercoat and it costs around $30 (? may have gone up lately)
(2018 dues paid)
Old 08-12-2017, 06:26 PM
BillL BillL is offline
thanks
I talked to Grady and he said he uses Evercoat metal glaze 416 and applies it with a thin stainless steel squeegee. I tried it when doing the canopy glassing and it will fill the finest scratches and pinholes. Pass both directions for best pinhole filling. Easily sanded with 320. Nearly all of it comes off with the squeegee. That will leave a good base for primer.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 08-12-2017, 06:33 PM
DanH's Avatar
DanH DanH is offline
To fix a few renegade pinholes found after spraying primer for a surface check? Sure, use almost anything...two-part polyester, drywall mud, lacquer putty, or whatever. Just be sure to sand off every speck on the surface, leaving only the filler inside the pinhole. Then shoot another coat of epoxy primer, followed by high build if you intend to block.
Bob....just shoot a good epoxy primer for your pinhole check. No worry.
Dan Horton
RV-8 SS
Barrett IO-390
