Old 08-12-2017, 08:54 AM
garyinflight garyinflight is offline
Default F-704G center section vertical bar (newbie)
I bought a project nearly completed a couple of years back (RV7) ,almost ready to fly now but looking at the plans I noticed the F-704G vertical bars are not installed. I have been trying to order a couple of these from Vans but F-704G is not recognized on the order list. Anyone have a suggestion?
Old 08-12-2017, 09:02 AM
jcarne's Avatar
jcarne jcarne is offline
Have you tried calling them? I have noticed not everything is in "the list".
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 08-12-2017, 09:59 AM
wjb's Avatar
wjb wjb is offline
This part comes as part of the F704 center section assembly, matched drilled (as I understand) as a set with the F704 E/F center section halves and the wing spars.
Check with Vans on this; this could be a difficult add-in after the fact. Two AN4 bolts go through this block to the wing spar web nutplates. Something needs to go in there to act as a spacer.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Engine hung!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 08-12-2017, 10:36 AM
Default Welcome aboard.
Gary, welcome to VAF
