Old 08-11-2017, 09:26 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Default Is there a better Zerk fitting?
In the last couple of months, two of us have had the same problem...the cheesy little red rubber cap on the Zerk fitting came off of one of the fittings on the prop hub, and the damned thing leaked a bit of grease which was then faintly visible on the canopy after landing (and on the cowling). It's not a big deal, but a PITA to decowl, remove the spinner, put a new cap on, recowl, clean everything up, etc. AND, we've had other friends who have had the same issue in the past.
It's not a huge deal, just an annoyance, but...*why* do these things leak like this, and (more importantly), is there a better Zerk out there somewhere?
Old 08-11-2017, 11:05 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Not your answer
I know this is not answering your question, But......
What I do, because I was taught by someone, is once I finish pumping grease in, and before I screw the zerk back in, I take a bent over piece of safety wire and remove enough grease that the zerk fitting is not pushing on the grease and creating pressure on the fitting.
Just a thought. YMMV
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 08-11-2017, 11:24 PM
RV7A Flyer's Avatar
Yep, we all do that...seems to help, I think, but once that little cap comes off, the grease seems to dribble out.
I wonder if the centrifugal force (okay, okay...yes, I took Physics...centripetal acceleration LOL!) moves the ball just a tad sideways. That spring in there can't be very strong, and although it might be low due to proximity to the center of rotation, there is *some* sideways force on it.
In any case, this isn't a one-off...3 planes, 3 or more instances of this annoyance...grrrrr....
Old 08-12-2017, 06:07 AM
DanH's Avatar
DanH DanH is offline
Unscrew the zerk, put a plug in the hole.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-12-2017, 06:19 AM
Ron B. Ron B. is offline
Dan, would you recommend using a plug in all holes if you were going that way, for balance?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-12-2017, 07:27 AM
RV6_flyer's Avatar
I use a small screwdriver out of my tool box instead of a piece of safety wire.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 08-12-2017, 08:33 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I just took delivery of a brand new Hartzell, and it came (from the factory) with only two zirks - one in each "leading edge" hole, and two plugs, one in each of the "trailing edge" holes. So that's two fewer zirks to leak.....
I guess the factory approves of the plug method.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-12-2017, 04:40 PM
n82rb's Avatar
n82rb n82rb is offline
breakaway wire around the rubber cap to keep it from coming off.....
bob burns
RV-4 N82RB
