Old 08-11-2017, 04:17 PM
SoaringTomcat SoaringTomcat is offline
Default RV aircraft leveling
Does anyone know the leveling points for an RV-7A or RV-6A for mounting ADAHRS? I'm figuring across the gunwales (for the Navy folk)(tip ups across the sidewall rails)
Old 08-12-2017, 06:45 AM
Vac Vac is offline
Default Yup
The longitudinal leveling reference are the canopy rails. Laterally, gunwale to gunwale should work fine!
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Old 08-12-2017, 07:13 AM
Thank you Vac. I was thinking the same thing but wasn't sure.
Old 08-12-2017, 07:33 AM
Pat Stewart Pat Stewart is offline
If you inflate the mains to about 42 you should be able to let the air out of the nose tire and be able to get it level forward and aft as well. Use a level for side to side and forward and aft, or you could take a digital level and duplicate it.,I have done it both ways.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 08-12-2017, 09:52 PM
lr172 lr172 is offline
The longerongs (gunwales) are only the leveling point as far foreward as the panel. Forward of this point they angle downhill, so you can't use the longerons behind the panel as a level reference.
N64LR
RV-10 in progress
